RCA F36450 36" TV Logo
Question about RCA F36450 36" TV
Good pictures but no sound just static - RCA F36450 36" TV
Posted by chapek220 on
Anonymous
    New Friend:
  • 57 Answers
Tvs get their picture and sound on different channels, and in europe, and in the usa the sound is on different channels, try in sound settings to set it to your area's sound defaults, so the tv will search for the sound at the right channels.
Posted on Apr 16, 2013
Emerson lc320em2 HAS A PICTURE FROM HDMI BUT NO SOUND IF I UNPLUG FROM CABLE BOX AND PLUG BACK IN SOUND COMES BACK ONCE I POWER OFF AND ON NO SOUND SOUND DOES WORK ON COAX CABLE
Chances are you have an issue with the main board. Those can be purchased on eBay for around $20.00. If you go the route of changing that board be sure to match the number of your board that is in the TV, don't search by model number as this model used several different boards and some are not interchangeable. One word of caution, use static precautions when handling the board, it should come in a static proof bag of wrapped in static bubble wrap ( generally pink in color) be at the set before unpacking the new board, just walking across carpet with it in your hand can damage a good board.Good luck!!
1helpful
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Have rca f36665 have picture but static for sound
it has a short in it.u will need a tv repairman sorry
1helpful
Model # F32649- TV has static, no picture no
RESOLDER LOOSE CONNECTION IN THE TUNER OR YOU NEED TO REPLACE THE TUNER
Volume problem with static sound
Call a good TV Tech and have him replace the Audio Amplifier IC on the board. This should cure the problem.
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
PLTV-32 GOOD PICTURE, Static Sound
If it is under warranty, you would be better off the return it for an exchange as the main board will need to be replaced. this board is not cheap. Good Luck
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
1helpful
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
