Suddenlink TiVo box remote
If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy. Or, type in the brand name to
your device into its search box, and press "Enter"
SOURCE: need to program suddenlink remote
You May Try ProView Codes and they are Manufactured in the Same Factory in China
SOURCE: Suddenlink remote will not operate my Olevia LCD TV
Device Key
Code
TV.
1610
NOTE: If the selected mode key emits a long blink, the entry is invalid. Repeat steps 2 through 3 and try entering the same code again.
NOTE: If the device does not have a PWR key, press the PLAY key.
SOURCE: where do i look for
Hi - My name is Tina and I am with Suddenlink. Please check our support site here for more info on programming your remotes. If you need further assistance, please contact me at tina-AT-suddenlink-DOT-com. Thanks!
SOURCE: I have the new suddenlink
Hi - My name is Tina and I am with Suddenlink. I am very sorry for the issues you are having with the remotes for your new DigitaLink boxes. If you would email me at tina-AT-suddenlink-DOT-com, I would be happy to help resolve this issue. Thanks!
SOURCE: need code to progam my
Hi - Tina from Suddenlink here. Please check our help site for remote troubleshooting tips. http://help.suddenlink.com/Television/Pages/RemoteControls.aspx
Hi cy- My name is Connie and I am with Suddenlink. I would be happy to assist you with your YouTube issue on your TiVo. Please email me at connie-AT-Suddenlink-DOT-com. Thanks!
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programming your remote please visit our self-help site at http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. You can choose the type of remote you have and it will pull up a list of usable codes. Thanks!
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Hi- My name is Shannon and I am with Suddenlink. If you are still having trouble programing your remote, you can find all the codes on our Suddenlink Support site, here: http://help.suddenlink.com/Television/Pages/RemoteControls.aspx. Thanks!
