SOURCE: The dash lights on my 2004 Toyota Corolla are not working
try checking the fuse box for blown fuses, if all fuses are ok, then the lightbulbs behind the dash need to be changed
SOURCE: 1984 toyota corolla 1.6 engine. How do i adjust
Carbureted models have a fast idle cam on the throttle,It is a screw that sets against a movable part,called the cam,when the engine heats up,the cam will drop upon tapping the gas pedal.Set the carb,while the engine is cold,by tapping the gas pedal,then adjust the fast idle cam screw by turning it in,with the engine running.Start out by turning the screw in a full turn before starting engine so it will run,then adjust the screw as the engine runs.
SOURCE: check engine light on - 98 toyota corolla, the
believe it or not , gas cap leakin will set it off
