Fan gets louder and louder then computer turns off
Jerry,do mean CPU-FAN.if the cpu-fan gets louder and louder as you
describe it.so are that for it's trying to cool the processor.when it can't
the computer turns of.you have to open the computer clean the fan
with compressed air (caned air) be careful look carefuly for dust at the
fans blades.
So picture guy, LOL
Most all boards have two power plugs from PSU, (power supply unit)
a 20 or 24pin and a 4 or 8pin.
The rest from PSU are for hardware, except if you have any video cards in pci-e slots, but they are not truly part of the motherboard they are addon.
Then from the case you have power button, reset, pled,hdled.
Sata ports on mobo, cpu fan, addon fans, DVD rom.
Front panel audio.
So now you have taken one memory stick and entered the BIOS, then tried each one.
You need to check each stick.
Now you put in your hdd erase disk, boot from it and you're going to erase your hdd so it's all clean for a fresh install.
Now you throw in the windows disk and you boot from it to install windows.
Right !!!
SOURCE: my Dell xps 600 won't startup
have you check the hardware of your computer? try to change the memory of your computer. and check the cables of your keyboard and mouse.. if there is any problem again try to contact me. thanks!
SOURCE: will not go beyond the boot screen at startup, pressing F2 or F12 does not respond
Got what ya need. send me your e-mail and I'll send you your Prize.
Don't forget to rate me at FixYa.
Good Luck
Tripod
[email protected]
SOURCE: Its a Dell XPS 400
Go into thye BIOS and turn off USB bootable device. The error is because the computer is trying to use the keyboadr to boot. At least it solved my problem.
SOURCE: Upgraded Studio XPS 435/9000 Ram - Now No Windows 7 Start
Check speed settings in BIOS, make sure that the sticks are the correct voltage for your motherboard. If the specs are correct, try a program like memtest86. This will tell you where the problem is, but it is up to you to find which stick that location is :) Might take some trial and error before you find the defective one!
SOURCE: Boot fails at Dell Inspiron logo at half way mark
you need to reset the processor and test your ram, one last thing make sure your dvd rom is working check cable make sure its connected
Testimonial: "Resetting the processor is something that would not come to my mind as a resolution. However, I did along with most others. It worked. Thanks!"
