Both usb ports are broken and i would like to try a pcmcia card. is there a pcmcia slot for this laptop?
SOURCE: ibm thinkpad a31p 2654
hi i had the same problem when trying to use memory stick have you installed the software that came with the device.
When you get that message cancel it as its not important when your device is plugged goto my computer and see if it is listed their.
If it is select it then it should be working.
If it is not listed then plug your device in the goto add hardware wizard and let the comp search for hardware devices when this has finished then scroll down the list untill you see your hardware device then select this and if you have disk tick box if not let the comp search the net for the correct software and settings.
Doing this solved the problem for me.
Let me know how you get on and if you need further assistance
SOURCE: HP pavilion dv1000 - PCMCIA slot not working
As they say look in the control panel /system/Device Manager under the listing for PCMCIA Adapters. If the device listed is an O2 Micro controller or OZ6912, click "contact hp"
SOURCE: replace broken usb port on dell latitude laptop
You will have to take the machine apart somewhat, or at least to the point of being able to disconnect and remove the usb port. Here's a link to the D600 service manual download. It will guide you through the breakdown process.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm
SOURCE: Acer Travelmate 3200 usb dont work
sir my name is ayaz ahmed im system administrator in quetta textile mills limited in karachi pakistan please solved my problem thanks best regard ayaz ahmed
SOURCE: IBM ThinkPad 560X 2640 (PCMCIA WiFi Card)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
