Question about Vacuums
Electrolux Unirapido not working green light flashes when start button is pressed!
Blue light is on while charging then once taken off to use it and the start button is pressed then the green light flashes and the cleaner does not work
Posted by keith_299 on
Cristi NC
    New Friend:
I have the same problem with this type of vacum. I have tried a lot of things but the problem is with the software included in a 20 pins chip on the pcb so it can not be repaired. But, if you look in the back of the vacum there is a rubber stopper wich hides 2 pins. Maybe those pins can be used to reset the vacums pcb. I really dont know because in can't test it any more. I solved my vacum bypassing the vacum mainboard (pcb). Now my internal battery is directly connected to the 2 motors using a simple switch to powering on and off. The original pcb is conected only to the batery, recharghing wires and led wires so i can recharge the batery as usual. Sorry for my english, hope you understanded what i was trying to explain. good luck
Posted on Feb 15, 2015
Jan Pavel
Same problem. How did you fix it? I replaced batteries but still doesn't work. Green led is flashing after press start button. Blue light is lighting when vacuum is charching.
Posted on Jun 30, 2013
5 Related Answers
bento_daniel
bento_daniel
SOURCE: I have a 2 year old Electrolux ergorapido cleaner
No, not worn out batteries.
For my experience, if the batteries were worn, they would charge with the blue led being on and after that, the vacuum wouldn't hold his charge. just that.
This is a different problem. Check the contacts between the charging station and the vacuum, mines got bent a bit and stopped making contact. This has happened twice and just fixed it about 30 min ago. That is why the led first lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
Posted on Sep 12, 2012
Anonymous
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
Anonymous
  • 833 Answers
SOURCE: Electrolux Oxygen Remote Control Z5654 Vacuum Cleaner
Check your hose for obstruction. That might be the problem. If not, you will probably need service.
Posted on Jan 02, 2008
SOURCE: electrolux oxy 3 vaccum has
You need a new hose http://evacuumstore.com/p-1298-electrolux-oxygen-3-ultra-vacuum-cleaner-hose-genuine-el7020.aspx
Posted on Apr 17, 2010
Anonymous
SOURCE: Electrolux Z8240 model vacuum cleaner
Inside ,the dust collection container, there at the far end is a white cone shape (another filter). I think you may find this covered in lint etc and if you reach in with your hand you can just pull the stuff off. Happened to me around the two month mark and I THINK, so far, so good. My machine is now not switching off and flashing lights at me and the suction is back to fabulous. Found this information on another obsure website. You would think electrolux would mention it in their "Troubleshooting Guide" GOOD LUCK
Posted on Nov 15, 2008
How do I reassemble electrolux EL855 Unirapido vacuum?
try utube for a video on putting together or try Electroilux website for the manual.
Sep 18, 2016 | Electrolux Vacuums
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Batteries are dead will not recharge
I do believe the company sells their own batteries for your product and even if they dont, you can always buy them yourself.First look on the back of your product and see what size you will need.
Nov 26, 2013 | Electrolux Zb2803 Unirapido Rechargeable...
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Unirapido wont charge
1) tes the power cord
2) test very well the batteries.
3) open and test the IC for charger and replace see the diagram attached.
God bless you
Jul 03, 2012 | Eureka 1014A Unirapido Stick Vacuum
Cleaning both filters on electrolux unirapido vacuum
I generally just run a paint brush over them. That usually cleans them satisfactorily.
May 24, 2012 | Vacuums
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
I'm looking for an electrolux oxygen repair manual
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner
i have 2, 1powers up and all 3 lights flash change hoses from the good one that work fine and it still wont run and the three blue lights continue to flash and wont run
Aug 08, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
