If we leave the tv off for 20 mins or so and then turn it back on, we can usually get a good hours worth of sound, but once it starts going off again it seems to happen every few minutes. Having read other problems on here I'm gathering that Alba isn't a reliable make. I know it was considered cheap, but we couldn't afford any more. Is there another cheap brand that would be better if this isn't a fixable problem?
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
SOURCE: Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Posted on Jan 03, 2010
SOURCE: AWA LCD TV - Blank screen (with sound) - picture appears for a few minutes
Rplace both capacitors on inverter board along with surface mount fuse on other side of board. The caps will aapear puffy on top.
Posted on Jan 04, 2010
SOURCE: polaroid tv screen goes black after 30 40 minutes,
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Posted on Jul 05, 2010
