Question about Motorola CP200 Two Way Radio
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Posted on Jul 02, 2013
SOURCE: radios dont recieve from each other..
The buttons you are referring to are programmable buttons, and it would depend on how they are programmed. In most cases depressing the buttons will not change the radio in such a way you could not communicate. When changes are made, they are changed back to normal by shutting the radio off and turning it back on. See page four of the owners manual.
You might want to read the section on the light on the radio on page 3. It may help.
Here is a copy of the owners manual: http://www.motorola.com/governmentandenterprise/contentdir/en_GB/Files/ProductInformation/6864110B13A_GP340_BUG_Multilingual.pdf
Other questions which come to mind: Have you changed antennas recently? Have you tried the radios together on all channels? Have you tried the radios in a different area? Have the radios been reprogrammed recently? Do you use a repeater? If so, the repeater may be not working or malfunctioning, or you are out of range, check with your service provider.
Posted on Nov 16, 2008
SOURCE: one radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Posted on Aug 11, 2009
