Question about Honda Alternator Crv 1999 99 2000 00 2001 01 Auto
HONDA CRV 2000 CHECK ENGINE LIGHT IS FLASHING.IDLING IS EXTREMELY SLOW,MORNING IGNITION IS VERY DIFFICULT. I ADJUSTED THE VALVES.BUT STILL THE PROBLEM PERSISTS.
CHECK ENGINE LIGHT IS FLASHING. IDLE IS VERY ROUGH MORNING IGNITION IS VERY DIFFICULT. I ADJUSTED THE VALVES
Posted by danukaj on
juan francisco
    New Friend:
I would like to know how to adjust the valves in engine B20B
Posted on Apr 19, 2013
1999 honda crv p0505
That code is for the idle speed control valve. Please follow the link P0505 Honda Idle Air Control Valve
My Honda CRV 2000 starts ok in the morning, but after turnng the eng. off and on ( going places in the city ) after the 4th time, it will not start ???
Your Ignition Coil could be the problem. It is starting to fail. It's losing contact and won't ignite your spark plugs when the engine is hot.
1helpful
3answers
Problems with my 97 Honda CRV. Erratic idle, stalls when coming to a stop. Replaced fuel filter, ignition coil, I don't know what else it could be. Possibly carbon deposits in throttle body iac maybe....
It could be the main relay and/or the ecm. Or it could be the distributor timing off.
Could be the ignition switch. Honda issued a recall on 1997 CRV ignitions in 2002.
Go to www.ahm-ownerlink.com and under quick tasks, click on the Get Recall Information.
99 isuzu trooper 3.0D difficult to start any morning when the engine is cold, when it does start it has a rough idle and sometimes cut out difficult to start again. both throttle sensors have been changed...
Engine is difficult to start when cold
  1. Check the battery condition, battery state of charge and starter motor current draw. Replace the battery if marginal and the starter motor if the current draw is beyond specification.
  2. Check the battery cable condition. Clean the battery terminals and replace corroded or damaged cables.
  3. Check the fuel system for proper operation. A fuel pump with insufficient fuel pressure or clogged injectors should be replaced.
  4. Check the engine's tune-up status. Note the tune-up specifications and check for items such as severely worn spark plugs; adjust or replace as needed. On vehicles with manually adjusted valve clearances, check for tight valves and adjust to specification.
  5. Check for a failed coolant temperature sensor, and replace if out of specification.
  6. heck the operation of the engine management systems for fuel and ignition; repair or replace failed components as necessary.
Engine is difficult to start when hot
  1. Check the air filter and air intake system. Replace the air filter if it is dirty or contaminated. Check the fresh air intake system for restrictions or blockage.
  2. Check for loose or deteriorated engine grounds and clean, tighten or replace as needed.
  3. Check for needed maintenance. Inspect tune-up and service related items such as spark plugs and engine oil condition, and check the operation of the engine fuel and ignition management system.
I have a 2002 Chevy Impala, it starts great in the morning when the engine is cold, but once the engine warms up it is very difficult to start. It cranks alot and even backfires sometimes. Also I noticed...
Have a 1997 CRV. The engine idle is way high and
Try changing your idle control valve, that should do the trick!
3helpful
Location of Idle control valve on 04 CRV
It's not a easy job but I'm pretty sure you had one of those problems where the idle surges if this is the case take out the air intake tube that leads to the throttle body, get a can of carburetor fluid and spray around the throttle body. You will need someone to start the car and hold the gas peddle to 2500 rpm while you do this the car will shut of when you do this, restart the car and repeat the process until half of the can is used up. Now check your antifreeze level fill if needed and reset you check engine light. Now you can take the idle air back and get your money.
2helpful
Honda crv 2000 computer reset
Ok,
1. ensure ignition off
2 . bridge the 2 pin connector, Put a piece of wire across both terminals
3.switch ignition on
4. SRS lamp should illuminate for 6 seconds
5.disconnect the bridge wire within 4 seconds of the warning lamp extinguishing
6.SRS lamp should illuminate 2 times, Codes erased
7.switch ignition off
8 Wait 10 seconds. switch ignition on and check SRS warning lamp operation.
hope this helps
Honda Alternator Crv 1999 99 2000 00 2001 01 Auto Logo
Top Honda Electrical Supplies Experts
Mike
john h
rostit
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
