Question about Protron PLTV-32 Television
Proton PLT3250 will not turn on. The red power button is out/off. I have moved to another outlet with no luck. What do u think?
No power when plugged in at multiple locations. Red stand by power lamp is not lite... as if no power to the tv
Posted by jliegh101 on
HOW DO I FIX MY SAMSUNG FLAT LCD SCREEN ?? IT WONT TURN ON AND THER IS A LIL RED LIGHT FLASHING IN THE FRONT OF IT
How old is the set The older models suffered from problems with the electrolytic capacitors in the power supply . No point in trying another power outlet or cable if the standby light has been flashing red . Power is obviously getting to the set if the standby is lit .
Has the set been a little slow staring from cold lately
Jan 03, 2015 | Samsung Televison & Video
Tv keeps turning on and off,
Repair/replace power board...
Sep 24, 2017 | Televison & Video
Just moved and rehooking up the plasma. Plasma does not turn on/has no power. Cable box plugged in, power cord rechecked to ensure plugged in correctly and checked power cord it has 110/120 at the plug...
Check that the outlets "GFCI" fuse or reset button hasn't been triggered. If this isn't a GFCI outlet, then verify the breaker is on. If still no luck, verify the device input power i.e. 110/240V
If you need further help, reach me via phone at https://www.6ya.com/expert/william_ecd28f5eabcb9eb6
Sep 26, 2017 | Pioneer PDP-6020FD 60 in. Plasma TV
I pressed the power button, but the tv wont turn on
Please check if the power cord is connected properly in the wall outlet and in the TV. Check the wall outlet. Has it got power? Check if there is red light when the power is switched on at the wall outlet. If there is red light then press the power button. Does the TV turn on? If not then your power button is defective and requires replacement as it is not making contact. Also please try to start your TV WITH THE REMOTE CONTROL. At times it helps.
Feb 12, 2011 | Sanyo Televison & Video
We have had our Proton TV for about 4 years. Tonight, we noticed that the red light was not on when trying to turn on the TV. We disconnected the TV to a different surge protector and wall outlet. We...
More likely to have power supply failure.
It is not for beginner to fix the power supply down to component level.
New power supply is about $60, shop will charge about $200+ for repair.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Please leave rating if it helps.
Jan 16, 2011 | Protron Televison & Video
Blinking red power button
How many times does the power indicator blink as thats a error code indicating which circuit has the problem.
Jun 01, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Cant locate a replacment power supply for LCD 32 Avion LU32A1A3
Hi, That is a real hard item to find. I found new ones for the 32" PLT3250 at Power-On.com No luck on Shop Jimmy, E-bay,or Encompass. I even tried part search. no luck. Sorry. Keep checking Ebay,and Shop Jimmy.They might get one in.
Oct 31, 2009 | Protron V33239 Television
Protron lcd tv getting no power
I have the same problem. I am told that I need a new power supply (adaptor) but from what I am reading on the Net, they are very rare and TV repairman told me he cannot find the part. I heard that Protron is out of business.
Jun 03, 2009 | Protron PLTV-32 Television
Cannot Turn on Monitor and Standby Red light is gone
If the power cable and power outlets are working and the TV still won't power up, then there's nothing much you can do. The power supply unit in your TV is blown. You'll have to get it replaced.
Jul 26, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Protron PLTV-32 Television Logo
71 people viewed this question
Top Protron Televison & Video Experts
matt martin
matt martin
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
