Panasonic AG-DVX100B DV Digital Camcorder Logo
Posted on Apr 14, 2013
DVX100b will not connect to 2010 iMac
I recently acquired a Panasonic AG-DVX100b and I am trying to capture the foatage into Final Cut Pro 6. However, my iMac will not recognize the camera and Final Cut displays that it cannot initialize the video deck. Any help? I have the camera in VCR mode and DV out is set to on. Thanks, Ryan
1 Related Answer
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Oct 31, 2010
SOURCE: Every time I connect my
Ok, well there is a workarround.. What one can do is simply use the AV cables, a USB Video IN Dongle, about $20.00. this then will allow you to connect the Camera to the PC, you can then "Stream" the Video from the Camera, to the PC, via the USB link, at FULL HD quality, save the "Played" Video as a suitable file, and do whatever you want with it. Using DVR software you simply, play on the recorder and Record on the DVR, and you'r good to go. Save as an MPEG4 or whatever format you want.
If you know how to edit the conf files then maybe you can make the existing scratch drive, persistent, making it unable to be removed.
Also you may like to try a Firewire to USB Dongle, this then will allow you to use the USB port, NOT the firewire..then at least you will be able to get data into the PC that way, although a wee bit slower, but this hardly matters in the big scheme of things.
tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
How to connect lavalier mic to panasonic dvx100b
Pretty easy, connect it to the xlr connector (hope your lav do have xlr connector) then swith the external mic switch on, phantom power switch to on, and front switch to mic (not line) and ajust the level.
1helpful
No sound when recording
Please get your microphone tested, also, you can try testing the recording using external microphone.
It seems that the problem is with microphone contacts or internal loose connections.
Seem to be a minor one, hope it will be resolved with above methods.
Thanks.
3answers
Importing Video to a Mac
XL2s are notorious for issues in interacting with final cut.
Simply put, sometimes it will work, sometimes it won't. But - there's a way around it.
Change the capture settings preset to 'non-controllable device'. Use the shuttle controls on top the handle of the XL2 to play back the footage as you wish. when you want to capture, click 'Capture Now' - It should do the trick.
Panasonic agdvx100b
Since it doesnt sound like you have a special external firewire hdd recorder that can direct connect to the camera, you gotta capture it with your pc and send it to your hdd after. Watch out that most of those hdd are set (partitionned) as they cant transfer file bigger than 4.xx gig... (You can usually set file recording from your pro capture software that built multiple file no more bigger than 4 gig per file...
DVX100B has no picture, no output on screen or to my laptop
Try a cleaning tape. It doesn't take much dirt to lose video playback with DV.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
