Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
Stefan Ivanov Posted on Apr 14, 2013
Mode not changing, stand on standby - Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
Why does my tecknika 40-920 lcd tv no longer turn on? The standby light is on but when i press the power on button/change channel button the stand by light changes to on, but the returns to standby mo
Fault with main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2answers
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
"Can't return from standby mode" the VGA,
Did you un-installed the previous graphic driver? Quick remody:
keep pressed the power button of the cpu and press again to start the computer.
If the system freezes in the stand by mode again;
Uninstall all drivers and re-install it gain. this might solve the problem.
16helpful
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
2helpful
2answers
Laptop not stand by
Please press the power button once. It should go in standby mode.
Putting sony vaio VGN-FW230J on stand by
just ckick on start-shutdown in that option you will get standby or just close laptop directly without shutting down & when u open it will come of standby mode....................Sameeraryan
Stand by mode
goto control panel ---> power options
select power schemes. power schemes should be "home/office desk
below that check "standby". You can select the time to go computer standby or never to go in standby mode.
1helpful
About laptop
Generally you can just hit the space bar a couple of times, and that should bring the machine out of Standby mode. However, if it is not Standby but Hibernate mode, you usually need to push the power button to bring it back from Hibernate.
You can adjust these and other power settings by going to the Control Panel, and clicking on the Power Options applet.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
