Question about Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range
We have a Sterling 1100E induction hob and have random problems with the hob not working at all, and tonight it just sits there in darkness but peeping constantly. The 2 ceramic rings work but not the
We have a Sterling 1100E with induction hob and have random problems with the hob not working at all, and tonight it just sits there in darkness but peeping constantly. The 2 ceramic rings work but not the induction. Any ideas?
    New Friend:
    Problem Solver:
  • 6 Answers
Some times the pots that you may be using are not designed for use in induction cooking. If you are, It might be the size of pot. The peeping sound might be the cook top looking for the pot. But when all else fails. Turn the stove off at the Breaker count to 12. Turn back on. Reboot. Hope one of these work.
Posted on Nov 20, 2014
Beko HII64403T induction hob, the left 2 rings packed in tonight, they went from 6 to E then turned off. the 2 right rings continued to work.
contact BEKO they will know why they did what they did and will know better what the fix will be . sounds like the 2 units might have burnt out due to not having the pots on them .
Nov 08, 2016 | Kitchen Ranges
Stoves 1100E range cooker. The induction hob now constantly refuses to work then randomly beeps and flashes for ages then works again. This is daily. When not working it will not switch on with the...
As with all appliances. When in doubt turn off the main breaker to your hob. Wait 20 seconds. This might fix it. Next try a different element. Some of the ranges require you to turn the breaker on with cook top covered. If it still has problems try changing your frying pan.
Buy it from a repeatable store so you can return it if it is not the pans. Lastly. Try moving it in the surface as it will click until it finds the pan. Good luck.
Feb 27, 2015 | Stoves Sterling 1100E Stainless Steel...
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
Feb 28, 2012 | Cooktops
Couldnt find a replacement instruction manual for the de dietrich dt 1714v induction hob
Several posts regarding instruction manuals for De dietrich induction hobs. Goto "http://www.dedietrich.co.uk/hobs-induction-hobs-c-55_23_38.html" scroll to find your model - select it, then look for a link to download manual.
Mar 30, 2010 | Kitchen Ranges
My De Deitrich induction hob wont heat up.
It is OK. The voltage was the problem. As soon as we went on to proper power again the hob worked normally.
Jan 10, 2010 | Kitchen Ranges
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Stoves Sterling 1100E Stainless Steel (Electric) Kitchen Range Logo
615 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Ismael Rodriguez...
Ned Halaweh
Ned Halaweh
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
