SOURCE: vpl-hs60 projector diagonal is off
You should be able to readjust the picture by moving the projector physically till you find the sweet spot.
SOURCE: VPL-HS60 Scene Dimming
Hi 3mad
This is quite a sticky one as this could either be the lamp or the Ballast ( lamp's powersupply )
And the bad thing is that the only way to be certain , would be to first replace the lamp and if this continues the Ballast as well.
I would suggest you to replace the lamp first , as this is never a waste , you could always keep it as a spare and 99% of the time it is the lamp will give this kind of problem.
Good luck and thanks for using Fixya !
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
