The error code 83c00020 appears when the printhead of the system fails. Fix the error by resetting it and changing the printhead of the printer. Follow the steps below to fix it.
Step 1: Turn on the printer and remove the power cord from it.
Step 2: Leave the printer for 60 seconds.
Step 3: Connect the power cord back to the printer.
Step 4: The printer should turn on automatic
Step 5: If the printer does not turn on automatically, then do it manually.
Step 6: Open the cartridge access door.
Step 7: Remove the printhead out of it and keep it aside for recycling.
Step 8: Buy the original printhead accessory from the HP website.
Step 9: Replace the printhead and close the cartridge access door.
Step 10: Following the above steps should have fixed the error.
For Support Call Our Toll-Free 1-866-293-9220
The Lt Cyan printhead may have been damaged by the paper jam.
I recommend removing all the printheads and power cycling the machine (turn off then back on) Install the printheads and check that each one says OK. Replace any that show recover or bad. (HP will replace free if it is under warranty - return it to the store you purchased it from)
You could have an inverter board problem. The inverter supplies high voltage to the CCFL lamp which provides the back-lighting.
For service. parts and DIY info check out LCD Parts - click in this link to their WEB site : - www.lcdparts.net
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Disply problem in my china mobile TOP-1 (Super Music King).
I have srcreen pin touch mobile. its working on all functions in mobile disply power is on.
but disply not showing any function on mobile no. on screen.
please help me. how i can solve this problem [email protected]
