Where is the oil pressure detector plug connected
SOURCE: My top gasket cover is leaking oil. I replaced the
this is the 16 valve one with a rubber ring type gasket ,what i do with these is clean it all up the i glue the rubber gasket in with evostick ,place face down on a flat bench t dry then grease the rubber and fit that always does it for me ,they fall out of the groove no matter how good or hard you try .Old trick i learnt in the ford factory when putting the big V manifolds on .
SOURCE: Fan belt diagram 1993 Opel astra
if you go to google it should tell you what it is.. you would have to type in the year model and type of vehical and also the type of motor
