I have fitted a new mains fridge heater element as my fridge was not working on mains .but still not working why
SOURCE: Dometic Caravan Fridge 7271
Your refrigerant may have completely separated in the system. Shut of the gas, disconnect the electrical and remove refrigerator from the coach or if you have sufficient room inside set it on a clean area. This operation is what is called burping the system.
1. From the base roll it onto the door and wait five minutes.
2. roll it onto the top and wait five minutes.
3. Roll it on the back and wait five minutes.
4. Return it to the base and wait five minutes.
Reinstall it or test it on electrical. It should show signs of cooling in about 30 minutes in the freezer compartment if the system is not plugged in the boiler.
SOURCE: Dometic RM2820 not working on AC Works fine on gas
Need to R&R the A/C heating element. Costs about $20.00
SOURCE: Zanussi Zx99/5SI fridge not chilling freezer Frozen over
Tell you what, first do a good 12 hour defrost and restart. Chances are you left the door ajar accidentally. (even though you say you never,) Most of the time there is the issue. If it continues after that, let me know and ill go through the defrost procedure (the cheap way)..
SOURCE: Dometic RM6270 Caravan Fridge.Hinges
you should be able to find any part you need
at
pplmotorhomes.com
they have always been able to help me in the past
SOURCE: Dometic RM2652 RV Refrigerator trips GFCI
Hi!!
Right beside the circuit panel, there is a grill, remove the 4 screws to gain access to the transformer/battery charger. You'll see a double power outlet, one cord is from fridge, the other is from the transformer. UNPLUG Transformer cord and reset breaker.
It will take a couple of minutes for the fridge to change to AC if you have it in AUTO. If everything works fine, REPAIR OR REPLACE TRANSFORMER/BATTERY CHARGER.
Don't forget to rate this answer, Good Luck!!!
