Question about Fitbit One Activity Tracker, Black
Reset to factory settings
How to reset fit bit one to factory settings. ( do not have base)
Albert Barkley
    Habit-Forming:
    New Friend:
  • 92 Answers
To factory reset your tracker:
1.Attach the charging cable to your tracker and plug the other end into a USB port.
2.Press and hold the button for approximately two seconds and without letting go of the button:
3.Remove the charging cable from your tracker.
4.Wait about seven to nine more seconds after removing the charging cable.
5.Let go of the button and hold it down again.
6.After "ALT" and a white screen flash, let go of the button and hold it down again.
7.After you feel a vibration, let go of the button and hold it down again.
After you see "ERROR," let go of the button and hold it down again.
After you see "ERASE," let go of the button. The tracker will turn off.
8.To turn your tracker back on, press the button or attach the charging cable (make sure to plug in the other end of the cable). If the time on your tracker reads 0:00, the reset was successful.
9.Next you'll tell your Fitbit account that you're setting up a new tracker.
10.If you use the Fitbit app, tap or click the Account icon (User-added image) and choose Set Up a Device.
11.Follow the instructions to replace your tracker.
Posted on Feb 18, 2017
How do I reset my forgotten password
Plug into computer and enter IP address on label into web address bar or hold reset button for 10-20 sec to reset to factory settings.
Sep 09, 2014 | D-Link Computers & Internet
How can I reset Compex SGX 3226 to default (factory) settings?
Your device is a bit light on support, a brief user manual can be found here: http://www.manualslib.com/manual/223934/Compex-Sgx3226.html#manual Usually there is a tiny recessed RESET button on the device, push and hold for 30 seconds or so will return to defaults.
Apr 02, 2013 | Compex Computers & Internet
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
How to reset the base setting
dear sir,
1.please your mobile phone model.
2.in the case of nokia phone you can follow this methods to reset the base settings.
3select main MENU > SETTINGS > PHONE > FACTORY SETTINGS, by clicking on factory settings,you need a password, the nokia default password is 1234,by typing this digit you can reset your phone settings.
thank you
Dec 26, 2010 | Cell Phones
Setting up wireless password
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 12, 2010 | Linksys Wireless-G WRT54G Router
Cannot remember log in info
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 12, 2010 | Linksys WRT54G2 Wireless Router
When my pc starts I get an error message concerning something missing in the dynamic link library. How do i fix this?
Try:
Resetting the Linksys Router to Factory Default
Step 1:
Step 2:
Step 3:
Step 1:
Step 2:
Step 3:
Click OK.
Related Articles:
Nov 08, 2010 | Linksys Wireless-G WRT54G Router
Linksys Group LIWRT160N Ultra RangePlus Wireless-N Broadband Router say's password is not enough characters, however I am using the right password. Why can't I set up this Window's computer?
Okay,i only option is to reset the router to its factory settings.
Please follow the steps to reset the router.
The router can be set to factory default by pressing the Reset button of the router and resetting through the router’s web-based setup page. Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. Any settings on the router will be erased and the router’s IP address will become “192.168.1.1,” the username is still blank, and the password will be “admin.”
To perform a hardware reset on your Linksys router follow the steps below.
Step 1:
Take note of the current settings of the device before resetting.
Step 2:
Press the Reset button of the router for 30 seconds.
Step 3:
If the normal reset does not work, unplug then plug back the router's power adapter while pressing the Reset button.
Step 1:
Access the router’s web-based setup page. .
NOTE: If you are using Mac to access the router’s web-based setup page,
Step 2:
When the router’s web-based setup page appears, click Administration then Factory Defaults.
Step 3:
Look for Restore Factory Defaults and select Yes.
Step 4:
May 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Screwdriver
it is probably a "tamper-proof' Torx head screw and you will need to get a set of tamper-proof Torx bits. Be certain the tamper-proof Torx bit will fit into a bit holder shaft ssmall enough in diameter to fit into any recessed holes that the screws are currently in.
Jul 30, 2008 | Rowenta Steam Generator DG050 Iron
Fitbit One Activity Tracker, Black Logo
3,760 people viewed this question
Top Fitbit Home Security Experts
Andrew Taylor
Andrew Taylor
robert
ray gallant
Are you a Fitbit Home Security Expert? Answer questions, earn points and help others
