Question about Mitac Mio 338 Pocket PC
Mitac mio 338 screen problem
I have a mitac mio 338 which is two years old,I have noticed that there are two lines across the screen that are about 2-3mms deep, the lines are not cracks as they only appear when the unit is turned on, is this a screen problem and how much is it to repair or is it cheaper to replace it ?
Posted by ncpayton on
5 Related Answers
Anonymous
SOURCE: mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
Posted on Jan 24, 2007
Anonymous
SOURCE: mitac mio 168 won't turn on
ITS THE BATTERY MANY ON EBAY :)
Posted on Apr 11, 2007
Anonymous
  • 74 Answers
SOURCE: mitac mio 268 digiwalker
268 or 168 ?? See this link
http://www.mio-tech.be/EN/support/168-manuals.php
Posted on Aug 28, 2008
Anonymous
  • 74 Answers
SOURCE: How to connect Mitac Mio P550 to a PC?
if you have xp you will need to download microsoft active sync from www.microsoft.com and if you have vista you will need microsoft sync centre, these will be the latest versions and should work fine good luck
Posted on Aug 09, 2009
NEXTLAB
Gery
  • 58 Answers
SOURCE: Mitac Mio 168 Digiwalker cannot recon SD card
your SD might be and SDHC or larger that 4GB. try to use a FAT32 formatted SD, no bigger than 4GB
Posted on Sep 04, 2009
Testimonial: "what if its bigger than 4GB?(i used an 8GB card actually)...i'll try and let you know...thanks"
Cost of display for s501
Jan 21, 2011 | Lands Phones
Mio 168 problems
Its memory may not be enough.
May 06, 2008 | Mitac Mio 168 Pocket PC
Sep 04, 2009 | Mitac Mio 168 Pocket PC
Aug 08, 2009 | Mitac Mio P550 Pocket PC
Mitac Mio C210 Update maps...
go to Mio Support and see if the C210 can even accept US maps. ALso, check ebay for cd with map restore or "Transmit Map' to blank 2 GB sd card.
Call Mio too.
Jul 06, 2009 | Mitac Mio C210 GPS Receiver
Mitac mio 168 problem
call the techie. That'll the best
Mar 25, 2017 | Mitac Mio 168 Pocket PC
Broken lcd screen on mitac mio c310x
You will need to replace a new lcd screen for your cracked mitac mio c310x gps,you can try to contact her,probably she can help you.
Email/MSN:[email protected]
SKYPE:keyudakim
Sep 18, 2008 | Mitac Mio P550 GPS Receiver
Mitac Mio 338 Pocket PC Logo
77 people viewed this question
Top Mitac Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
matt
matt
Larry Ng
Larry Ng
Are you a Mitac Computer and Internet Expert? Answer questions, earn points and help others
