I have a Sony Wega that is about three yrs. old. This last week the red in the picture has all but gone. I went to the settings and tried to set the Hue setting all the way to red but no luck. I am wondering if a new bulb will fix this. I don't want to buy a new bulb if this is not the problem.
Please Help!!
Todd
SOURCE: color variation and blinking red light on bottom of tv
The light flashing 5 times is normal at turn on as the set is monitoring current drain on the pictures tube cathodes. Any speakers near the set that have un-shielded magnets could possibly cause color issues.
SOURCE: Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
SOURCE: Sony KF 42WE610 blinking red (non-lamp light) won't turn on
Lamp Cover is not attached properly.
Please remove lamp cover and
make sure to fix it properly, well seated in its place and tight screw.
There is a safety switch under lamp cover that should be pressed when
lamp cover is closed.
if it could not solve ur problem ..then u have to change LAMP..
