Question about Hobart HL600 Legacy Stand Mixer
Hobart HL-800 displays b-9d code
Not mixing
My Hobart mixer HL-400 shots off undr the heavy loads
that is because you are overloading it. the 400 watt is only a medium power. I have a 800 watt stand and i do load it and it takes it.
do you have it on an extension cord?
are you using the wrong attachment?
regards
sir jdht
Apr 25, 2017 | Hobart Food Mixers
Our hobart HL 600,no display in speed and timer,even there a 24vac,supply in timer controller,only bowl up and down are working
If you have 24 VAC to the timer board and still have no display, then you need a new timer board.
Aug 02, 2010 | Hobart H600 Stand Mixer
What is error code 99 for a hobart HL 600 mixer?
error 99 stands for communication fault between timer board and the sr drive.there are 5 things that can cause this error.1.rs-485 cable disconnected or malfunction 2.1 con monitordisconnected or malfunction. 3.run/stop wiring disconnected or malfunction. 4.timer board malfunction. 5.sr drive malfunction. hope this helps, dont forget to vote, thanks, monomoy
Jan 29, 2010 | Hobart HL600 Legacy Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
HL 600 timer board I think
Sorry so late but the reason you need the kit is because the potentiometer (the knob that selects the time) is no longer part of the timer board.You need the pot,and board.I'm a hobart tech,if any other questions let me know.
Jan 05, 2009 | Hobart A200 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart HL600 Legacy Stand Mixer Logo
148 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
