Motorcycles Logo
Anonymous Posted on Apr 13, 2013
When flushingtoilet water backs up inshower - Motorcycles
  • Anonymous Apr 14, 2013
    the problem is in the sanipro it takes ages to pump the water out of the shower, weve tried sink unblocker pumps ect when the maccerator starts up the water clears very fast. but just lately weve noticed it takes longer before the moter kicks in , so the shower tray is half full, ive pludged it with a plundger and it clears for the momment,
Anonymous
Level 3:
President:
  • Master 949 Answers
  • Posted on Apr 13, 2013
Anonymous
Master
Level 3:
President:
Answers
949
Questions
0
Helped
420796
Points
3655
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
  • Anonymous Apr 13, 2013
    ***** Sorry, forgot to say, wait till all the water goes down, about 10mins before you add the liquid plumber so it's not to diluted.
  • Anonymous Apr 15, 2013
    Thanks for rating, very much appreciated.
How do I drain water out of ice machine
Turn the water supply off to the refrigerator. After complete at the bottom of the refrigerator there is a water supply tube. Put a small container under it to catch the water, loosen the hose and let both ends drain in container.
Now go inside refrigerator, actually the freezer, you will see where the line comes into the fridge. Loosen that connection and blow air through tube. Hook that connection back up back up, hook connection on back of fridge back up, then turn water back on for supply and all should be fresh water.
PS: Don't forget to grain water out of water station on front of refrigerator.
Ge gss25pgmf
Before replacing water valve open open back panel disconnected water line of water dispensser and tell some 1 to press water actuator on dispensor and check water pressure from it. If its slow then it can be valve or it can be filter housing. Repalce both if confuse.
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
I changed my wtaer filter and water still wont come out
turn of the water and remove the line at back of frig . put line in bucket and turn water back on if no water change the service valve . if water comes out of line the its most likley the water valve on the back of frig. ( replace it ) and if the valve on back is not bad the water line has frozen up inside the unit . but this would only be the foutain not the ice mker .. hope this helps .mm
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
How to take out air from the engine for smart car
Open the temp gauge sensor (located in the back , top of the engine) and please make sure to open the lock and not to lose it as you will need it to tighten the sensor in its place. Open the water bottle and pour water in it and let the water come out from the back (the sensor) , you will see air bubbles coming out with the water , but keep on pouring water till you see no bubbles what so ever. put sensor back in its place while water bottle is full and while water is still coming out from the back to make sure that no air escapes inside with the water.You might need another person to help you pouring water while you are in the back.
No water getting to the ice maker.
Hi
Check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further clarifications and Do rate the solution as "FixYa" if you found this helpful.
Thanks
Rylee
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
