2000 Jaguar S-Type Logo
Posted on Mar 09, 2009
How do I change my clck in my 2002 jaguar - 2000 Jaguar S-Type
Anonymous
Level 1:
  • Contributor 13 Answers
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
13
Questions
Helped
8169
Points
56
Press the menu control for two secs the display should show adjust clock with hours flashing press seek tuning control to adjust hours once set press the menu briefly the display shows mins flashing do same with mins to exit menu press any button or wait 4 secs
10helpful
3answers
How do i reset the alarm on my 2002 s type jaguar after changing the battery?
Insert your key in the ignition and turn it on and off. Push the Arm button until you hear it lock. That does the trick for me always. I own a 02 jag myself.
Jaguar S-type 2002 How to change lenguage in the odometer
audio and communication system. The optional "JaguarVoice" speech recognition system even allows you to change the settings without having to touch any buttons or the LCD screen -- and in any of five languages including English, Spanish, German, French and Italian. The instrumentation is crisp and easy-to-read (though I never did figure out how to reset the odometer), and the trademark maple wood dash and leather everywhere never let you forget you're behind the wheel of a Jaguar. http://www.dashboardprogramming.com/?page_id=3
What reasonable transmission fluid can i buy for a jaguar xtype 2002 3.0 i am changing my transmision, also how many quarts thanks
they are supposed to be sealed for life so no need to change any fluid try to buy a low milage one !! sorry to state the obvious
3helpful
My jaguar x type 2.0 auto is leaking transmission fluid and there was smoke coming from the vehicle as i drove it. Its a 2002 model what could be the problem?
front pump seal is leaking or oil pan seal is leaking and hitting the exhaust pipe. time for a transmisson oil change and fliter replacement. costs about $200.00 at any tranny shop.
2answers
Changing oil in jaguar 2002 s type? Where is the oil filter?
jag-you-are would prefer that you take your car to one of their service centers!! probably has an internal filter element that needs special equip. to access and change out.lot of high end cars have that type of filter now. my brothers mercedes mid-1990s doesn't even have a tranny dip-stick! need special tools to check level! hard to be a 'shade-tree' mechanic anymore!
good luck!
Just changed brakes but the pedal will not biuld pressure
antilock brake actuator has air trapped in it.
5helpful
Jaquar X Type Oxygen Sensor
two at the front on the exhaust cat and two on the rear, and yes if there tight
I also started getting a warning light today 'powertrain malfunction' on my 2002 Jaguar x-type
You might have to change the shift cable. I had the problem last year (2007), worked perfectly after that......:)
1helpful
Slow Jaguar x type
check your intake manifold for leaks if you recently had your spark plugs change, or it could be incorrect spark plugs, or bad temperature senser.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
