New sharp aquos tv asking for me to enter wsp pin into router. how do I do that
SOURCE: 2Wire USB Remote NDIS Ethernet driver
U can get driver from this site
http://www.dsldepot.com/dslmodem.asp?mm=9
Posted on Jul 10, 2008
SOURCE: 2wire modem/router keeps rebooting
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
Posted on Jul 29, 2008
The drivers are located on the 2wire website. You need to go to support > downloads > Gateways > 100/1000. Those drivers will work for any 2wire gateway that has USB.
Posted on Dec 03, 2008
SOURCE: install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Posted on Feb 07, 2009
SOURCE: I received a new 2wire 2701HG-B modem router for
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway, 192.168.1.254
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping 192.168.1.254 and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Posted on Sep 13, 2009
Mar 05, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Jul 10, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Dec 18, 2013 | Televison & Video
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
Mar 12, 2011 | 2wire 2700HG-B Router (2700HGB)
Jan 22, 2011 | 2wire (1000-000057-000) Modem
Oct 25, 2008 | Sharp Aquos LC-32D40U Television
Sep 06, 2008 | 2wire (1000-400108-001) Router
Jul 15, 2008 | 2wire 1800HG Router (RG1800HG00)
Apr 15, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Nov 02, 2017 | 2wire (1000-400108-001) Router
61 people viewed this question
