Rockford Fosgate Punch P4004 Car Audio Amplifier Logo
Question about Rockford Fosgate Punch P4004 Car Audio Amplifier
I would like to know the watts for my F10a 10in 4ohm freeair kicker subwoofer
Posted by marcus on
2 Related Answers
Anonymous
SOURCE: Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Posted on Sep 01, 2007
Anonymous
  • 41 Answers
SOURCE: how to wire kicker 07cvr124 4ohm duel voicecoil 12in sub to my rockford fosgate 4channel punch 600r amplifyer
run the positive from one voice coil the the negative on th other than take th left over positive from one voice coil and the negative from the other and bridge it to the amp use the blue sub wire but u will have to buy a 1 unto to splitter to hook up ur rcas from amp
Posted on Mar 30, 2012
I have a Alpine MRP-M350 amp and then I have 2 10 Kicker Freair F10A Subwoofers. What's the best set up for this combo?
From the plus(+) of the speaker output on the amplifier run a cable to the plus(+) on the voice coil of the first subwoofer then follow thru with the same cable to the plus(+) of the other subwoofer.
From the minus(-) of the speaker output on the amplifier, run a cale to the minus(-) of the first subwoofer then follow thru with the same cable to the minus(-) of the other subwoofer.
This will make your amplifier run @ 2OHMS and provide you with 350 Watt RMS which will work fine even if you run your subwooffers free air(without a box))
hope this helps
dreamsystems
I have one 10in. Kicker L7. and a Kenwood KAC-929 1000 watt amp. What are all the wires i should buy that can make this setup run?
Need an amp kit up to 1000 watts, speaker wire. Amp kits have most of the wires needed such as, power, ground, and remote wire. As well as all the connectors needed.
3helpful
Need to wire two dvc 15 in kicer l7 to 1 ohm
Hello goldy6569,
To wire the L72's at 1ohm, simply connect both +'s and -"s on each sub together. Then connect to your amp terminals.
With 2ohm DVC's, you can have either a 1ohm load or a 4ohm load. The diagrams are here (I know it's the website of a Kicker competitor, but their "wiring wizard" is simply the best).
Hope this helps.
1helpful
How do you wire four 12 inch kicker cvr dual voice coil, to a 2400 watt 1 channel class d amp
Hello brysonford00,
The wiring configuration depends on what final impedance you want the amp to see. If the subs are 4ohm DVC's, you can wire them to present a 2ohm impedance or an 8ohm impedance. The diagrams are here. If your subs are 2ohm DVC's, the wiring is the same. The impedances will be 1ohm and 4ohms.
Hope this helps.
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
1helpful
Yes i was wondering what would be the best way to wire my system. i have to kicker L5 4 ohm 10in subs and one kicker 1000 watt mano amp. what wolud be the way to get the best bass out as possible.
Hello eaglepower_2,
Well, to get the maximum power from the amp, you really need a 2ω load. Unfortunately, you cannot get that from 2 L5's with 4ω voice coils. You can get either 1ω which will burn your amp up, or you can get 4ω, and your amp will put about 500 watts RMS into that load.
To get the most from your amp, you really needed the L5's with 2ω voice coils. That way, you could run the voice coils in series and the subs in parallel, resulting in a 2ω load, exactly what your amp likes. If you can exchange them for the 2ω model, I would.
Here's the link to Kicker's manual for the ZX-1000.
http://www.kicker.com/sites/default/files/2008%20ZX%201000%201500%202500-1%20e01%20web.pdf
Hope this helps.
What Amp would i need to push three Kicker L7 12's?
It depends on the specific subs and exactly what you want out of them. You have practically unlimited choices for amps.
The 10" L7 has a power range of from 30-600 watts RMS, the 12" from 50-750 watts, and the 15" from 100-1000 watts.
So if you have the 10's, you would want an amp that puts out at least 90 watts RMS and not more that 1,800. Unless you are really into SPL and have an unlimited budget, it's probably best to go somewhere in between.
Keep in mind that these Kickers need to be in a proper enclosure. They like a little more volume to work as compared to RF's or MTX's and some others.
2answers
What amp size do I need
If the subs are going to be wired at 2 ohms you will need a class d amp that is 1200 watts at two ohms rms i would say you should probably be running zero gauge wire and at least a two fared cap
2helpful
3answers
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Top Rockford Fosgate Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
