Press the "Clock" button, then the correct number buttons to set the desired time. Press "Clock" again to confirm.
Press
"Timer" to set the timer function. Choose the desired countdown time by
pressing the number pads, then the "Start/Stop" button. Press "Timer,"
then "Reset" to cancel the timer.
Press the number pads to select a cooking
time. Press "Power" to use a power less than 100 percent using the
number "9" for 90 percent of full power, "8" for 80 percent, "7" for 70
percent, and so forth. Press "Start" to begin cooking.
Press
"Defrost by Weight" to defrost a food item by the weight of the item.
Enter the weight of the item, then touch "Start" to begin. Enter the
food weight by pounds and ounces, using a "0" for a decimal. For
instance, if the food weighs 1 pound, 2 ounces, enter "1," "0," "2,"
then "Start".
Select "Speed Defrost" to defrost food quickly. Enter the desired cooking time and press "Start."
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while
you are out of the house, freeing up your day. Set the timer on a
Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
Fill
the insert of the single oven slow cooker with food and cover it with
the lid. At least a quarter of the insert should be filled with liquid
to keep the environment moist during long cooking times.
Press
the "On/Off" button on the left side of the electronic control panel in
the front of the appliance. This will turn on the slow cooker to the
low heat "Warm" setting.
Press
the "Cook Time" button on the right side of the electronic control
panel to add hours to the timer which will show a total time in hours
with a red digital display. Continue to press the button until the
display indicates the desired cook time in one-hour increments up to 10
hours. The cooker will automatically adjust the temperature setting
based on the amount of time you programmed on the timer. Cooking times
of six hours or less automatically start on "High" heat and times of
seven hours or more will start on "Low" heat. A small indicator light
will come on below the word to tell you the cooking temperature.
