Question about Casio Fx-992s Scientific Calculator
Log base b - Casio Fx-992s Scientific Calculator
How do I put in log to base 4 of x
That depends on the make and model of the calculator. A few calculators have a logBASE or similar function which takes an arbitrary base. Most only have logs to base e (ln) and base 10 (log).
However, the log of x to any base can be calculated on any calculator with logs as either
log x / log base
or
ln x / ln base
Sep 05, 2014 | Office Equipment & Supplies
Tip
The Log function!!
I calculators you can't change or set the base of 'log' is default 10 so you need to know these:
log x (base y) = log x / log y
when log x it's automatic log x (base 10) here some examples:
log 8 (base 2) = log 8 / log 2
log 27 (base 3) = log 27 / log 3
and the base it's default 10 again, and that is how you need to use it in calculators(no bases), and here the explanation to this:
log x (base y) = log x (base 10) / log y (base 10) = (log x / log 10) / (log y / log 10) = (log x / log 10) * (log 10 / log y) = log x / log y
here so other stuff about 'log' :
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
on Jul 07, 2009 | Casio fx-300ES Calculator
Change base log
The 30XIIS only calculates logs to base e (natural log, ln) and base 10 (common log, log). However logs to any base can be calculated indirectly.
To calculate log base b of x, calculate either log(x)/log(b) or ln(x)/ln(b).
Dec 09, 2013 | Texas Instruments TI 30XIIS Scientific...
How do I find log with a different base (not 10)?
Calculate the log (base 10) of the number, then divide the result by the log (base 10) of the base.
For example, to calculate the base-3 log of 9, calculate the log of 9 to get 0.954 . Divide that by the log of 3 (about 0.477) to get 2.0 .
Since 9 is 3 squared, the log base 3 of 9 is 2, as we just calculated.
Mar 28, 2012 | Office Equipment & Supplies
How to get ans log of bases other then 10
You can calculate the log to any base B by dividing the base-10 log by the log-base-10 of the base B. You can also calculate it by dividing the natural log by the natural log of B.
For example, to calculate the base-3 log of 10, calculate
log(10) / log(3)
or
ln(10) / ln(3)
Jul 20, 2011 | Casio FX-65 Calculator
Conversion of log base 10 to log base 2
To calculate the log base 2 of a value, calculate its log and then divide by the log of 2. You can use either the log or the ln keys, but be consistent. For example, to calculate the log base 2 of 16, you can calculate either log(16)/log(2) or ln(16)/ln(2).
Nov 27, 2010 | Casio FX570MS Scientific Calculator
How do i do log base x problems (other than log base 10) on the datexx ds 883?
Calculate it the same way as on most other calculators, using the relation
log_b(x) = log(x)/log(b) = ln(x)/ln(b)
In words, calculate the log base 10 of x divided by the log base 10 of the base. You can also use the natural log function instead of the common (base 10) log--just be consistent.
Oct 19, 2010 | DateXX DS-883 Calculator
I need help with a change of base formula problem.
It's simple here some logs:
log x base y = log x / log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Jul 01, 2009 | Texas Instruments TI-83 Plus Calculator
Log function on casio fx-9750GA Plus
Look it's simple in the calculator the default base is 10 so when you input log 3 its log 3 base 10 so:
maybe you know in math log x base y = log x / log y . So if you need log 3 base 3 its => log 3 / log 3 (by the way its 1)
Mar 27, 2009 | Casio FX-300MS Calculator
How do i perform the calculation of log (base 2) 8? The answer should be 3....that is it is the inverse calculation of 2 cubed =8. Can any one help with the log calculation?
Yes look you can't enter the base in calculators it's default 10 so use:
so instead of log 8 base 2 input log 8 / log 2 it's easy
hope you understand :)
Feb 21, 2009 | Sharp EL-531VB Calculator
Casio Fx-992s Scientific Calculator Logo
55 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
