Question about Targus AKB33US Bluetooth Wireless Keyboard
Targus akb33us keyboard
Spacebar
I updated my ipad to ios7 and my Targus Bluetooth keyboard does not work anymore.
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
Myspacebarisnotworking
Greetings,
You may have some small item underneath the spacebar. The spacebar will "pop up" if you use a screwdriver or something to pry it up from the keyboard. Insert it near the B on the top side of the spacebar and pry up towards you. Clean out from underneath and reattach it.
I broke my spacebar off my laptop gateway computer! How do i fix this?
Of all the keys on the keyboard, replacing the SPACEBAR is probably the most difficult. The SPACEBAR is kept even by a metal wire that is inserted into slots on each leg of the plastic bar key. However, you have to get the wire into the slots without depressing the wire. If you push the wire down, you compress the wire and installation becomes impossible. As a general rule, do not remove the SPACEBAR unless absolutely necessary. If you remove the SPACEBAR, remove several surrounding key caps also. This will let you get some tools under the SPACEBAR wire later on. Once the SPACEBAR is reinserted, you can easily replace any of the other key caps.
Targus PA870 Universal Wireless Foldable Keyboard driver
you can visit this site for the driver of the targus keyboard u want
http://www.targus.com/us/product_details.aspx?sku=pa870u
would be glad to help u out
thank-you for quires
2answers
Keyboard Failure
Buy a new one.not worth fixing.RICHARDM69
6helpful
2answers
Spacebar,wont,work,after,spillin small,amount,of,juice. took.rubber,piece,off,of,my, spacebar,and,cleaned,it. but,can't,get,it,back,on. This,is,on,my,laptop
The sugar goes into the contacts and permanently deamages the keyboard. NOT REPAIRABLE. The laptop keyboards are not very expensive. You will only get that problem solved by replacing the keyboard.
1helpful
Spacebar not responding on Toshiba laptop Satellite
Since the spacebar is the most used key on the keyboard, it is likely a hardware failure of the spacebar itself. Replacement keyboards can be found on EBay and normally run about $20
Targus keyboard installation
The problem is most likely with the driver being for an older MIPS processor (like the one in the Casio E-100). Where did you obtain this keyboard. Targus did not really support the EM500 when the keyboard came out. Now, they don't at all. Email Targus www.targus.com or Stowaway www.thinkoutside.com for a new driver.
Targus AKB33US Bluetooth Wireless Keyboard Logo
Top Targus Computers & Internet Experts
Raj Patel
ADMIN Canada
ADMIN Canada
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
