I have a wirless set up in my house but a certain part of my house has a black spot (no wireless signal) I also have a unsed Belkin Wireless G+ router I have considered buying a PowerLine Homeplug with Wireless N Access Point Starter Kit which is double the price of a normal powerline adapter with out wireless built in. Does anybody know if I can use Belkin Wireless G+ router with a non-wirless belkin adapter? My question
Have a dead spot, get a indoor booster.
http://www.radioddity.com/2000mw-indoor-broadband-amplifier-signal-booster-for-802-11b-g-wireless-routers-sh24bta-2w.html?___store=default&___store=default
The best best adapter and most powerful is a Alpha, AWUS036NHR. B/G/N
This thing is amazing.
http://www.amazon.com/Alfa-AWUS036NHR-High-Gain-Wireless-N-Strongest/dp/B005ETA5K2
Just use the unused one to create an access point.To do so you need to login on the web UI of the router and change to an access point instead of a infrastructure.
SOURCE: how to set up network on belkin G+ wireless usb adapter
do you have a Wireless Router + Broadband modem? This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet. something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection. If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01 or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
SOURCE: Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
SOURCE: how to conect belkin wireless g usb net adapter to xbox 360
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
SOURCE: Belkin Wireless G Gaming Adapter not acquiring IP
when you insert your adapter in the computer do you get found new hardware balloon if not then try with a different computer if still doesn`t then your adapter has gone faulty.if you do get the balloon then i would suggest you to install the adapter with latest driver.take care.
SOURCE: Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
