Question about Parallax Power Supply Parallax 7300 Series 45 Amp Electrical Converter/Charger
Wiring parallax 7300 series converter
I had to replace the converter section only. I though I only had 4 wires to deal with but when I went to install it I can not remember where the white wire was attached. Help
Posted by Dennis Merryman on
mwredd
    Problem Solver:
  • 6 Answers
If the white wire is the large # 10 AWG on the DC output, connect it to terminal "D" on the backside of the DC fuse panel. The front side of terminal "D" carries the 12 volt system negative or battery negative wiring. Refer to the wiring label pasted to the inside surface of the drop open door for terminal locations.
If the white wire is the smaller #12 AWG, 120VAC "common" or neutral, connect it to the isolated neutral terminal bar in the 120VAC circuit breaker compartment where the other white 120VAC neutral wiring is connected. The 120VAC isolated neutral terminal bar will have a full length plastic insulator under it and will not be directly connected to the chassis.
Posted on Oct 14, 2014
How do I install 2 additional 12v lead acid batteries to a removable battery box in an electric scooter that already has 4 - 12v batteries?
How are the batteries wired? If they are wired series the system is 48V and adding 2 batteries won't be easy (need a DC to DC converter with enough capacity to be useful). If they are wired parallel then just keep adding in parallel.
It is possible that the 4 batteries are wired as 2 pair of 2 in series for a 24V system. IN that case wire additional batteries in series then the PAIR in parallel with the 2 pair already in place.
Sep 29, 2018 | Electric Health & Beauty
Why does the cooling fan run all the time ?
I suggest you call Parallax Power Supply
100 W 11
th
St. Suite 100
Anderson, IN 46016
Ph: (800) 443-4859 Fax: 765-608-5235
Jul 02, 2014 | Parallax Power Supply Parallax 7300 Series...
Battery is installed properly and keeps blowing 40 amp fuse on the out put side.
Hi there, Ive had the same problem that came from a worn out wire that was toucing, this may be the problem.
May 26, 2014 | Parallax Power Supply PARALLAX POWER 7465...
Capacator in lower left corner is blown apart from an 220v generator connection.... where can i get a replacement capacator or board ?
The capacitors are industry standard items that can be cross referenced from the component markings, values, or part numbers referenced on the components through several national component suppliers such as Digikey, Mouser Electronics, or Newark Electronics. If a single bulk capacitor has blown, both should be replaced as the other will have been stressed and should not be trusted to be functionally sound.
Apr 11, 2014 | Parallax Power Supply Parallax 7300 Series...
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
Need adiagram for replacing 3 wire factory humbuckers with 4 wire seymour duncans
These are for the seymour duncan JB pickup which uses an extra switch for a coil tap. If you tie the leads of the switch you can avoid using it in which it would become a normal humbucker.3_8_2013_7_29_41_pm.jpg
Sep 26, 2011 | Music
P0133, P0420 and P0430 i went to MCV for inspection and they rejected the car. gave me the above codes. when i went to authorized mechanic, he told me that both the catalyic converters are bad and cost...
code p 0133 refers to heated oxygen sensor (HO2S) 1 bank 1---slow response ===causes ---heating inoperative --- wiring ---HO2S
also refers to oxygen sensor (O2S) 1 bank 1--slow response ===causes ---wiring ---O2S
also refers toHO2S 1 bank 1--no signal====causes wiring ---HO2S
the HO2S is the sensor in the exhaust manifold before the cat converter and reads the exhaust gas composition to report to the ECM to adjust air fuel mixture
For this code the HO2S needs replacing
the reference to an O2 S is the sensor after the cat converter and reports on the cat performance
code p0420 refers to catalytic converter bank 1-- efficiency below threshold ==== causes cat converter ---wiring ---HO2S
code p 0430 refers to the same as p 0420 but cat converter bank 2 causes the same including the HO2S
I would first get both HO2S sensors ( bank 1 and bank 2) replaced then have the fault codes read
if the cat converters are sill showing as the 420-430 codes then muffler shops have cheaper cats that what you were quoted
Dec 16, 2017 | 2004 Suzuki Verona
Check engine light on needs o2 censor can i replace it myselfans where is it located
These replacements can be simple, but you will need to get a sensor socket or wrench in order to replace and some can be really rusted in the exhaust. The sensors are located ( depending on motor size v-6 or 4 cylinder) one on the exhaust manifold at the front of the motor and one on the catalytic converter. It will be a short stubby piece with 3-4 wires coming out of it.
Feb 17, 2011 | 2004 Chevrolet Impala
Parallax Power Supply Parallax 7300 Series 45 Amp Electrical Converter/Charger Logo
1,318 people viewed this question
Top Parallax Power Supply Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you a Parallax Power Supply Electronics - Other Expert? Answer questions, earn points and help others
