Question about Samsung Star Cell Phones
How can i stop the freezing of a schm828c samsung phone
Posted by mike calvin alston on
Sagar Prajapati
    New Friend:
You can not stop samsung fone freezing.every that fone had that problem
Posted on Apr 12, 2013
  • Sagar Prajapati Apr 12, 2013
Stop freezing and turning off
Through the unfreeze you can remove your phone freeze.You can unfreeze your phone by unfreeze code.If you need an unfreeze code visit SuperUnlockCodes.com This service can be used to unlock and unfreeze Samsung mobile phones locked to any mobile network
Aug 29, 2014 | Samsung Galaxy Cell Phones
Samsung gt-s5511t
My Samsung Phone FM radio has stopped working and freezes my phone when I switch to it any help please.
Jan 09, 2014 | Samsung Cell Phones
How do i reset my samsung schm828c gp tracfone
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 09, 2012 | Cell Phones
Locked samsung schm828c
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 27, 2012 | Samsung Cell Phones
Cell phone freeze
If the Phone says Phone Freeze it's because of wrong code entered.It's Samsung Phone ?Because samsung Phone will say Phone Freezed..You need to Unfreeze it using the Unfreeze Code.You can get the Unfreeze code for Samsung Phone European Phones at Unlocking4u.com/samsung-europe-unlocking-service/rs6wp10/ and Unfreeze it
May 25, 2012 | Cell Phones
Why does my phone keep freezing
This can't be fixed since our phones seem to be left behind by the complexities of the appns we trying to run. The appn designers keep code running in the background when you try to do something which zapps your phones processing speed. Due to this my only advice is take it slowely, get a hefty micro SD and put as much on there as you can from your phone. Get practice removing the battery to restart your phone. You will need to be familiar with this since I have to do this at least twice a day. The other key issue is that the low quality back of our phones (specifically Samsung Galaxy W) does not secure the battery as well as other phones. As a result, the battery can jiggle and wiggle slightly which causes phone freeze. They are great phones but just a bit toooo cold as things stand and really need to warm up to stop the freeze. Only Samsung can do this!
Oct 25, 2011 | Samsung Galaxy S GTI9000 Smartphone
My Samsung Smiley died, when I plug it in to charge the charging screen comes up but freezes and stays frozen. The battery icon shows up and the blue bar at the bottom starts to load but stops halfway and...
i am really sorry for that i think your phone is in coma not died.dnt worry first see the ways of charging lines.for that you must have knowledge of mobile.
Jun 29, 2011 | Samsung T239 Cell Phone
Caould you please advise how i can unfreeze my samsung s7070
Hi,when a phone freezes, it is because an application installed in the phone has been affected by Virus and also when there are too much application in the phone and the memory is to occupied it can cause freezing of the phone.
First you check the memory status of the phone to see if it is filled up so you can delete some data application you are not making use off.
After checking that you can now know the next step to take if you will need to flash the phone to restore back and stop the freezing of the phone.
You can pass your comment if you need any help.
Take care.
Oct 08, 2010 | Samsung S7070 Cell Phone
Samsung A707 Phone freeze unlock code
I hate to be the bearer of bad news but phone freeze is pretty much the end of the line. That is a security feature in the base firmware. If a security code is entered incorrectly too many times, the phone completely locks up. At that point, it is pretty much useless.
Samsung has implemented this so that you have to send it back to them.
Unless you know someone that can reflash the main firmware, its bricked.
Please be fair and at least rate as helpful, because there really is no "fix ya" solution available for phone freeze.
Jul 06, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
