Question about Compaq Computers & Internet
Which video files will Compaq DVD Burner burn to a DVD
Posted by davidmckelve on
odiebugs
    President:
  • 949 Answers
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Posted on Apr 12, 2013
Nanny
    Genius:
  • Compaq Master
  • 2,351 Answers
Maybe it's because your PC does not have DVD player software which has DVD decoder. Try to play the DVD on some other players. You could download some free DVD player programs.
Posted on Nov 06, 2019
3 Related Answers
SOURCE: How do I burn a DVD of a file on my PC desktop?
use cd writing software like nero or ashampoo ashampoo is a light version
you can use inbuilt writer software if you are using vista and higher just drag the file to your drive in xp or higher to burn the disk
Posted on Jun 11, 2009
Anonymous
  • 6 Answers
SOURCE: generic errors only burns 75% of file ; happens on bith internal & external DVD RW
Very possible you got a bunk batch of blank media. But could also be the burning program itself (IE NERO) Try to reinstall what ever program you are using
Posted on Aug 22, 2009
graysand
wilfred graham
  • 558 Answers
SOURCE: DVD burner won't burn using Premier Pro.
have you set it as your primary recording device under options?
Posted on Sep 21, 2009
I can not burn a cd with GH24NS70 cd/dvd drive . No software with the drive. Can you e-mail me the software for this drive. Thanks....
there are plenty of free burning software programs on the internet
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
Active ISO Burner will allow you to burn an ISO image file to CD-R, CD-RW, DVD-R, DVD+R, DVD+R DL(Dual Layer), DVD-RW and DVD+RW (including double layer, DL). [email protected] ISO Burner software accepts command line parameters to automate ISO images burning process.
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
Sep 06, 2011 | LG ELECTRO LG DVDRW GH24NS70 24X SATA with...
Tip
How to convert and burn any videos to DVD?
This guide helps you to convert and burn AVI/MPEG/DivX/Mov/RMVB and any videos to DVD:
Tools required: Cucusoft video to DVD converter
More information of dvd creator
resource:free dvd burner
Install and launch Cucusoft video to DVD converter pro, you will see the UI below.
1. Select radio button "To DVD"
2.choose the "merge" or "batch" tab.
3.Click "Open" button to open your movie file(s)
4. (optional) Set your preference. Region "4" in red frames can set the output MPEG properties.
5. (Optional) Set the advanced settings as following.
6. Click "Convert" button to start the conversion task
7. After you click "Convert" button, the following dialog will pop up automatically.
8. After video conversion done, the "CD/DVD Burning engine" will be launched automatically. Please choose the DVD burner.
9.Please place a DVD-/+R/RW disc into your DVD burner. If it is arewritable disc, the program will erase the disc before burning DVDdisc.
10. When burning DVD is done, the DVD disc will be ejectautomatically. You can also find the output file at the output folder.
on Feb 03, 2010 | Computers & Internet
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
I have a lg cd/dvd burner, supermulti. How do i find out if it supports cd&g burning or copying karaoke discs? I dont know a model number, its internal.
if its a cd/dvd burner it will depend on which burning sofware you are using some will support burning media files and dvd's some will not you could search the internet for some free ones if you do not have any of this software cnetdownload.com also majorgeeks have lots of this free software
i will attach some links you could try if they dont suit your needs just uninstall them
http://www.nero.com/eng/downloads-nbl-free.php
http://www.majorgeeks.com/BurnAware_Free_d5839.html
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://www.majorgeeks.com/ImgBurn_d4870.html
http://www.majorgeeks.com/ShrinkTo5_d4755.html a dvd copying program
http://download.cnet.com/free-easy-cd-dvd/3000-2646_4-10627009.html
hope this helps
Apr 17, 2011 | LG Computers & Internet
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
IMATION EXTERNAL DVD BURNER FOR MAC
you have to check if your MAC (with OSX 10.3) supports such device (imation 16x external dvd burner). if so, well look for the driver of the imation dvd burner in the internet.
you could search for it by typing in on google or any other search engine and look for the driver with is for MAC (OSX 10.3).
Mar 13, 2008 | Computers & Internet
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Macbook dvd burning not possible ?
If you don't know how to burn DVD on Mac, I think this step by step guide would help you
http://www.mac-dvd.com/mac-guide/how-to-convert-video-to-dvd-on-mac.html
Jan 13, 2008 | Computers & Internet
Computers & Internet Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Toby Lee
Toby Lee
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
