Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
My phones won't connect to my WBR-1310 router unless I go upstairs nearly every time and unplug/reset it. My laptop always seemed to connect with no problem. Now I have a wireless card in my des
Posted by Ken Koziol on
FREE ROBUX ON ROBLOX
    Habit-Forming:
    New Friend:
  • 24 Answers
Hi baby *****
Posted on Oct 25, 2017
5 Related Answers
Anonymous
  • 143 Answers
SOURCE: Wireless connection problem whenever I switch on my laptop
you need to isolate first which of the devices is giving you the problem.
- check first the connection from your modem by connecting a computer directly to it. check if you'll loose the connection from the modem. if so, you need to check with your internet provider if they're having maintenance from time to time since that could be the reason why the router is not providing the connection to your laptop automatically and you need to restart it to sync with the modem first.
- if you have a proper/stable connection directly from the modem, next thing to check is the connection from the router. check if your wired computers are getting the same problem. if so, you may need to check for loose/faulty cables or you may need to upgrade the firmware of your router. if the wired computers are not getting the same problem, it's time to check the wireless settings of the router.
* access the router's page by typing http://192.168.0.1 on your web browser's address bar (default username is "admin" while the default password is "password")
* go to the wireless settings page and check if the wireless name (ssid) is not the default. if it's still using the default ssid, customized it to prevent interference from other dlink network near your area
- if you have check the modem and the router, it's now time to check the wireless adapter, make sure that it is connected to your own network. if you are using it's software utility, make sure that you have created a profile using the same ssid as of your router. you can also update the driver of your wireless card if you have checked the above mentioned and you're still having the same problem
you can also try to use another wireless computer and check if it'll experience the same problem to properly isolate the if it's the router or the wireless adapter problem. you can also try to install the wireless card to another computer and check if you'll have a stable conection. if so, there could be a software (like a firewall or an antivirus software) that is giving you the problem.
hope this'll help you and just ask me if you have other concern.
ciao!
Posted on Jul 02, 2008
Anonymous
  • 65 Answers
SOURCE: wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Posted on Nov 27, 2008
Anonymous
SOURCE: D-Link Wireless Router WBR-1310, Version A1
I had the same problem.
Make sure you turn off all the security with the software in package then slowly turn it all back on, on piece at a time. For whatever reason, it comes with MAC address filtering already turned on, which makes it impossible to see if you don't have the right info put in to the computer that the router was configured with.
Posted on Feb 27, 2009
Anonymous
  • 167 Answers
SOURCE: why does my D Link 802 11g Wireless Router WBR
Make sure your computer has the ability to get online wirelessly.
Posted on Mar 09, 2009
Donald B Stoll
  • 597 Answers
SOURCE: Wireless Home network will not stay connected to internet
So you have a DSL modem connected to a router connected to a wireless router connected to both your computers? Sounds like you need to just get a wireless modem and throw all the routers away.
Posted on Jun 01, 2009
Not able to open settings page (DLINK (WBR-1310)
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to3.05)Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 01, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Wbr 1310 does not seem to connect to laptop. erthnet cable is connected from modem to wan port on router and another erthnet cable from port 1 on router to laptop erthnet connection. no...
connect your computer to the router and open internet explorer and in the address bar type, 192.168.0.1 and push enter. it might be 192.168.1.1, don't remember. login and setup your internet connection. if you have cable internet set it to DHCP. if you have DSL you will have to get the settings off the providers web site. you can also try resetting the router. with the power on, press the tiny reset button on the back of the router for about ten seconds. you will see the lights go out and come back on. once the router reboots try it again. Good luck.
Aug 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Hello, I've had my D-Link router for about 5 years now. The model is WBR-1310. The connection worked fine up until today. I took off the connectivity between the router and my PC about 6 months ago,...
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Wireless signal gets to laptop , but won't connect
you need to setup WPA2 password for your network to access.
Jun 27, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I have a D-Link WBR-1310 router. It worked fine on Thursday evening. Now my laptop and my TIVO cannot even detect the router. I have tried resetting it and even unplugging the router and plugging it...
I suggest you RESET the D-Link back to the default setting and configure the wireless settings again.
http://192.168.0.1
Jun 18, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Lost my password
Press the reset hole on the back of the router in with a pen for at least 30 seconds. This will reset your router to factory settings
Dec 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My laptop say i am connected with internet access but it is not; when i check network magic there is a red x through router and laptop; how do i fix this...have unplugged and reset but nothing works; seems...
uninstall the network magic . that software has lot of issues.
You can uninstall the program and try to connect using the windows utility. that is very easy and that works properly.
Is there any computer connected to the router with the cable. If yes then open the router set up page and check the wireless settings of the router.
Click here for more information about the router and network
Jan 13, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a wireless network- 2 laptops plus 1 desktop usually connected wirelessly. Today, I hit the reset on my Tmobile Dlink router and I am unable to log on of my laptops back onto network. When I use...
try unplugging the router for about 5 minutes and then plugging it back in. I would also unplug the modem at the same time, then plugging the power back opn for the modem and then plugging the router back in too. should reset ur issues
Jul 15, 2009 | D-Link 802.11g Wireless Router WBR-1310...
WBR-1310. No admin logon, only f/w upgrade page
Download firmware from site
http://www.dlink.com/products/?tab=1&pid=WBR-1310&rev=WBR-1310
DLink states the login issue has been fixed with firmware v1.04 3/28/07
Remember to get the right one for your unit model. You must connect a RJ45 cable to the router and computer you have downloaded the firmware to and remember which directory it's in. When it asks for the firmware put in the target location (c:\my documents\xxxxx) of the firmware file. Good luck.
Jul 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect to the internet
Mike, Try setting up a new connection in Internet Options in Control Panel. Please let me know how this works for you.
thanks
Jan 24, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
131 people viewed this question
Top D-Link Computers & Internet Experts
Mike
Jeffrey Groves
Jeffrey Groves
RockTheHood
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
