DISH Network ES161256 21.0 IR / UHF Pro Remote Kit for Receivers ES16 Logo
Posted on Apr 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dish tv 21.1 control solutions
Only have intermittent control
  • Official Brand Answer 263 Answers
  • Posted on Apr 25, 2013
dish
Level 0:
Answers
263
Questions
0
Helped
108338
Points
330
Craneserv710,
I would need more information on if it has intermittent control of TV or satellite to provide the best information. I have listed some steps to try below for either situation!
Satellite:
If the remote has intermittent use on the satellite, ensure there is nothing that may be causing interference. For a TV1, this could be a fluorescent light, or a direct heat source blocking the IR signal. If it is a TV2, interference may be caused by a device that is powered on. You can try turning off equipment to see if interference is removed, or you can try moving the antenna on the back of the receiver. If it is sticking straight up, turn it parallel with the receiver. If it is laying flat, put it straight up.
Television:
If the intermittent control is for the TV functions, you may need to program a new code into the remote. There are multiple codes for a remote and some will work completely, while others only provide intermittent functions.
Let me know if you have any other questions, or if you can provide additional details! I'll be happy to assist you.
Tommy Faust
DISH Social Media Representative
How to pair Westinghouse Remote RM-21 with Dish Network
I believe that dish has it's own type of remotes and the remote that you purchased is specifically compatible with your tv and not necessarily the Dish box. This would explain the difference in the code lengths. So, you would need to call dish and ask them what remote's are compatible with Dish. Thank you.
1helpful
Sanyo TV Code for Dish remote 21.0 IR/UHF PRO only operates TV Power and Volume Functions.
Hello Witt Thomas,
I can understand the concern and wanting the remote to work the TV Menus. It is possible with our remotes, however it depends on the TV itself. I've seen instances where there are 2 TV's in one house, and 1 will do it, while the other won't.
If you have tried all of the remote codes, and none work, the only other options we have available are to try a powr scan, or teach the remote. This link http://www.mydish.com/support/teach-learning-remote-20-21 can provide the steps on how to teach that model of remote control!
Let me know if you have any other questions.
Tommy Faust
My box is receiving the feed intermittantly. is there a common cold solder joint problem?
Hello this is Nick Franta with DISH.
During the intermittent signal loss/freezing are any error messages popping up on your screen? From the information provided the best solution would be to unplug the receiver from the outlet for 10 seconds. Also try to press the up and down buttons on the receiver itself when its freezing to see if it allows you to change the channel. If this doesn't resolve the issue we would need to send you a replacement receiver. Let us know if you need any further help!
2helpful
2answers
Have a new Vizio LCD tv , My Dish remote will not work only manual at the the box what wrong
Hello, Daniel Busa with Dish Network customer service. on those lcd tv's they will interfere with your remote. You have two solutions, you can turn off the back light feature in the tv menu, or you can set the remote to a uhf frequency which will probably require a new remote.
1helpful
I have ( Apex digital LD4688 ) I neeed the code. Thank you.
I install dish network. i have tried all versions of dish remotes, . the only one that works is Dish Network 21.0 Learning Remote. it will work with all dish products and i have programed it for this tv apex ld4688 hd and it works great.here is a link for the manual on how to use.
http://www.satelliteguys.us/dish-network-forum/158496-dish-network-21-0-learning-remote.html
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Remote Problem
Remote codes are programmed into the remote at time of and since the TV was manufactured after the remote it will be unable to have the code as TV manufacturers change codes often. You can try having a 20 or 21 remote sent to you but ensure it will work with your receiver. These remotes are programmable and ar able to learn functions of other remotes. Thanks for using Fix Ya.
I get 110 direct to receiver or 119 direct to receiver (dish 500) but when I use the sw21 switch I only get one
Hi
Thanks for using FixYa. As per the issue you described, I think you are not able to switch to Channel 21. It means that it has either been deleted from the projection TV or you have set the parental control guides. To correct the former, access the Channel controls by pushing the "Menu" button and maneuver the channel icon, then press "+". Select "Favorite Channels," and then the "+" button again. Then type the number of the channel (21) you are not able to watch and press the "+" button one last time. To access the parental control channels, press "Menu" and maneuver the Parent icon, and press "+." Enter your four-digit password and use the arrows on the remote to change the overall settings. After performing this procedure hit the "+" key one more time. Now you will be able to watch channel 21 as before.
Please tell me the model number of your Unit so that I can provide you with model specific information.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
1helpful
2answers
Dish network UHF remote works intermittently.
If you extend the small antenna that is on the back of the receiver by using a short cable and a barrel connector to get the antenna out of the entertainment center or out from the TV this will help alot
21helpful
9answers
CANT GET TOSHIBA CT 90302 TO PROGRAM
I had the same problem, and the solution above/below that says to use code 018 worked for me. Yeah!!!
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
