Question about Intel Dot Station (INTC300AIO) PC Desktop
Intel dot station 2300, how to replace memory, Step for open
5 Related Answers
Chintu-KPV
Chintu-KPV
  • 202 Answers
SOURCE: intel dot station destop
I think u need more info on intel dot station :)
Please visit the following link
http://www.dotstation.info/
The basic spec is:
Intel® Dot Station – Standard Configuration
Celeron 300 CPU
810 E motherboard.
64 MB / 128MB SD RAM, DIMM's, expandable to 256 MB.
10 GB HDD expandable to 80 GB and above.
10 / 100, ethernet / lan card for connecting to server, broadband
connectivity etc.
56 Kbps fax modem voice V 90.
Sound card.
Compact keyboard.
2 stereo speakers in built.
Touchpad mouse in built in the keyboard (like laptop computers).
3 USB 1.1 ports.
14" colour monitor, 0.28 DP, 1024 x 768 integrated.
Linux operating system. (Installation cost extra for Windows® XP)
All manuals, cables, original Intel sealed box packing.
Have a nice day
Posted on Feb 02, 2008
Anonymous
  • 28 Answers
SOURCE: how can i operate intel dot station
Just use a usb key board or use ps2 keyboard by usb to ps2 convertor and open bios function by F2 key and change boot option to usb then use an external cd drive and insert windowsXp cd and follow intruction of installing windows Some notes on changing linux system to windows is here:
http://support.microsoft.com/kb/314458
and this note is also useful for installing windows.
http://www.adobe.com/products/XPinstallnotes.html
Posted on Mar 03, 2009
Kiranbala
Balakiran Reddy
  • 91 Answers
SOURCE: Remove Hard Disk from Intel Dot Station
i am also having the same PC, its mreally hard to open the cabinet, you need to remove almost 30 screws, i did of my own, but its very complicated, if u want any suggestions to remove give me reply. Bye
Posted on Mar 20, 2009
Anonymous
  • 225 Answers
SOURCE: intel dot station 2300 pc power supply problem
I suggest to buy a new replacement Power Supply to immediately fix your problem, instead of getting the circuit diagram & try to locate/replace the part/s that might be cold soldered /defective which if not handled properly will result to another possible problem. best regards
Posted on May 23, 2009
Anonymous
  • 15 Answers
SOURCE: i want circuit diagram of intel dot station 2300
It's very relly hard to get the circuit diagram of intel dot station 2300..
you should try another way to solve your problem
you can tell what problem you are having with it.,
Posted on Jul 08, 2009
How can format the intel dot station pc
You can boot from a USB memory stick and format.
The best tool for the job is freeware and can be found at http://www.ultimatebootcd.com/
Simply download software - extract archive using winrar (http://www.rarlab.com/download.htm) and open up the folder UBCD then open the folder TOOLS > WIN32 > UBCD2USB
Inside this folder is a command line script that guides you trough the process of creating a bootable USB memory stick.
Boot from this newly created memory stick to access tools to format the computer.
Jan 12, 2011 | Intel Dot Station (INTC300AIO) PC Desktop
Intel DOt.station system is can not reboot the system, and how open the monitor head.
intel DOt.station system is can not reboot the system, and how open the monitor head
Jun 10, 2010 | Intel Dot Station (INTC300AIO) PC Desktop
I have an intel dot station 2300, it doesn't start ,it sounds with short beep continuosly like below "... ... ... ..."
A continual beep is usually a sign of the cable being backwards or upside down whatever the case may be
Jan 18, 2010 | HP Compaq Presario SR1720NX (EL435AA) PC...
I want circuit diagram of intel dot station 2300
Jul 06, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Intel dot station 2300 pc power supply problem
May 22, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
How to press key in keyboard going BIOS setup in model intel cerlon dot.station 2300
dear to entering in motherboard setting,,you can press one of the following keys,,,,
1-delete button press
2-F2 key
3-F8 key
4-F10 key
these keys are helpful for you.please rate it
Apr 13, 2009 | Intel Computers & Internet
Intel dot station english manual
You can download Intel Dot Station keyboard driver and keyboard layout at
www.nsexim.com
Apr 07, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Dot station 2300 does't start
if your smps working properly in another pc your motherboard is faulty. you have repair it. but beofre this you should chek power cable or your power point.
Dec 27, 2007 | HP Compaq Presario SR1720NX (EL435AA) PC...
Intel Dot Station (INTC300AIO) PC Desktop Logo
214 people viewed this question
Top Intel Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
