Question about Singer 3116 Simple
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
Every time i go to sew the whole thing gets jammed and all tangled underneath where the bobbin is
Posted by gina buck on
  • josephamoi May 16, 2013
    Presser feet must be down when sewing & if rethreading does not solve the problem, most likely it needs some minor adjustment & you need to refer to your local singer technician
Debbi's Sewing Machine Repair
  • Singer Master
  • 7,365 Answers
Try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Posted on Apr 12, 2013
2 Related Answers
WonderTech
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
Anonymous
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Posted on Mar 21, 2010
Thread gets tangled underneath
around the post? is the bobbin and bobbin case in the machine?
Feb 18, 2014 | Janome Sewing Machines
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
The bobbin thread keeps getting all tangled. i have cleaned it all out several times but when i start sewing again it does it again...what am i doing wrong?
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the bobbin is turned the right way inside the case
make sure the thread has not come off the thread take up lever,
if it has, try putting some tape over the thread take up lever, but
make sure to leave a whole to get the thread thru
Jul 27, 2012 | Janome Memory Craft 9000 Computerized...
The cotton keeps getting caught up in the bobbin area
try these suggestions
1. change needle--flat side to the back of the machine
2. needle must the correct one for the fabric
3. check the bobbin to make sure it's not damaged or warped
4. check the bobbin case( the thing that holds the bobbin) to see if there
are any burrs on it or see if it's damaged is some way
make sure the bobbin case fit's snuggly into the hookrace
5.it's also possible that the machine could be out of time
Apr 18, 2012 | Sewing Machines
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
sew.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
The bobbin string gets tangled in a big mess and jams the machine
adjust the thread tightness. thread tension might be loose enough. be sure also the the bobbin inside the machine is place correctly! reversed placement would result in bigger mess.
Feb 26, 2008 | Brother XR-65t Mechanical Sewing Machine
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Birdsnest and machine jams
Ok, this is real simple. pull the thread from the bobbin up through the bottom of the machine near the needle. also, hold the thread that you threaded through the needle with the other strand on the left of the needle. hold them there for a few stitches... and wahla! no more birds nest.
May 10, 2007 | Euro-Pro Shark 80 - 7133
Singer 3116 Simple Logo
187 people viewed this question
Top Singer Sewing Machines Experts
Irene Tulloch
Chris Wetmore
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
