Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Nenmore 795-51024--15 months old--frezzer doesn't frezze-piece of junk-don't buy
Posted by richard fischer on
Tip
My tip is not to buy this piece of junk
The tablet only works when parental controls are activated. You can't use the parental controls if their server is down, and it's been down for over 24 hours. A lot of kids have a useless paper weight that they can't play with, which they got for Christmas. I don't want a table that can only be used if their server is up, and they don't even have back up servers. This piece of "equipment" is a complete joke. Don't buy it if you haven't already, and return it if you have. Anything that this is thie poorly designed, in which they haven't thought through what happens if their server is down, has to be full of problems from poor design and just simply not thinking!
on Dec 26, 2013 | Toys R Us Tabeo
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Paper wont feed 11x17-keeps jamming ( problem with the rollers?)
For first clear rollers w/alcool or orig clearing solvent. If it doesn't solve Your problem remove the rear cover and controll the little fingers hanging in the way of sheet edge. Some of them may be in wrong position because of missing or released spiral. Fix it back with a medical clip or you may remove the whole finger (one piece) if You don't find the spiral. Control and clean the turning surface.
You need strong light in the spot because of the usally black accessories.
Don't miss monthly cleaning procedure.
May 15, 2012 | Canon ImageRUNNER 3235i Black and White...
CS26, couple of months old. Was using one day, stopped to get a drink came back to start and it wouldn't, rope pulled very easily and didn't sound like it was turning the engine. Opened it up and...
i was given one of these trimmers thats almost new but missing a bunch of parts so im seeking one that owner declares as 'junk'. ill buy and pay cash. locked up okay, blown engine ok, just need handle and body parts with aircleaner assly. anyone got one to sell me? seven06 three22 fourthree79. call mark, regards!
Jul 10, 2011 | Ryobi 26CC, 22 In. Hedge Trimmer
How does a Plymouth breeze drive on long distance travels. ??
That's a ten year old vehicle isn't it?
Not a top of the line car to begin with
I don't know, but I wouldn't buy one
Should be a Mitsubishi in there,you
don't want that. The timing belt will go
the second day you have it & the transaxles
are junk
Jun 28, 2011 | Plymouth Breeze Cars & Trucks
I have a 2007 street bob took it out of basement charged battery and started right up.now bike wont even turn over battery had over 12 volts starter checked out alright replaced batteries in fob cant...
I can't figure out whether your problem is with the bike or the security system. I have no experience with security systems and don't have a clue. I'd take the battery out of the bike and take it somewhere to have it "load tested". Just because a battery shows 12 volts with a meter doesn't mean it's any good. Put a load on it (like the starter does) and you may find that it's a piece of junk. If it won't start then, I'd suspect the security system has it locked out. Sorry I can't help with that but I'm an old school biker and I don't mess with security systems.
Good Luck
Steve
Apr 13, 2011 | Harley Davidson FXDBI Street Bob...
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
