Frame no full
Either put in a new memory card or erase the existing photos. See page 132 of this manual.
Alternatively, change the frame number setting as described on page 98.
Posted on Apr 12, 2013
SOURCE: Hi, When i turn on
Hi christoph8550,
Please follow the below steps :-
Make sure that you remove any memory cards from your camera and then switch on your camera.
After you have done that , you would have access only to your camera's built in memory for storing photos.
Now , try clicking a photo and see if it get's saved, if it does , then you need to format your memory card even if you feel you have it empty and then insert and check if the problem persists.
If it does not save and give you the same error , now it's time for you to format your camera's internal memory , just deleting them is not enough many times.
After you have done formatting this problem would go away for sure.
Let me know in case you have any queries.
Hope this helps ..:)
Posted on Jun 19, 2011
SOURCE: memory card is showing full but won't play
Try to delete one picture which you don't want, or one which is fuzzy,etc. Try it then. If it cannot play from the card, then some problem exists in the camera.
Posted on Oct 31, 2011
SOURCE: My Kodak M583 camera won't upload photos to my iphotoWhat's your problem?
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Posted on Mar 18, 2012
SOURCE: ihave sony full hd HC1080 camera i can't transfer photos from camera
( CARD READER TO PC)
The best and easy way is took out the memory card from the camera & insert in the memory card Reader. Then connect card reader with the PC. Now open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. b>OR
( CAMERA TO PC USED USB CORD )
Connect the camera with data cable and turn on the camera. After that open My computer and there you can find removal disk driver ( For Example G: ). Open the driver and copy all the folders from there to your computer. After complete the transfer open the folder. You will find all the photos there. http://www.ehow.com/how_2282213_transfer-pictures-from-camera-computer.html
Posted on Aug 10, 2012
Jul 15, 2017 | Samsung SL202 / PL50 Digital Camera
Jun 22, 2017 | Cameras
Aug 03, 2012 | Cameras
Jun 24, 2012 | Fuji FinePix A345 Digital Camera
Oct 31, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Jul 05, 2011 | Fuji FinePix S8000fd Digital Camera
Jun 19, 2011 | Samsung Digimax S700 Digital Camera
Aug 22, 2010 | Nikon Coolpix 2000 Digital Camera
Dec 16, 2009 | Fuji FinePix S5500 Digital Camera
Mar 01, 2009 | Sigma 17-70mm f/2.8-4.5 DC for Canon EOS
49 people viewed this question
