Hi ajdean01 - I see that your tub appears to be leaking. Here are a few troubleshooting tips that may help you get to the root cause: · First, be sure that your tub is not overloaded. Sometimes when overfilled, water can and will slosh outside of the unit. · If the tub is not overfilled, check your hoses and other connections. Like most laundry units, there is always some vibration associated with the functionality of the machine. As the appliance is used over time, hoses and other connections can loosen and begin to leak. Be sure to secure any loose connections. · If the above items did not assist you in resolving the issue, it could be a number of other underlying causes - primarily an electronic pressure sensor, switch, thermistor or the unit's main control board. These parts are commonly replaced by experienced service technicians.
SOURCE: frigidaire affinity indicates 'err' light - nothing else
Dear Abhkss
ngfam at you service,
Sounds like you need service for electronic parts!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at [email protected] for futher info
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
SOURCE: Frigidaire Affinity Front load washer,
E10 code indicates there is no water supply.This can be confirmed by :
E10 also means that your cold water is coming in too slow, disconnect the
cold water hose and check to see if the screen on your washing machine
is clogged. If the screen is clean and the hose has good pressure then
you will need to replace the water valve on your machine--- this is the
piece that the hoses directly connect to.
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
