Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How can i get to the ballast ballare fmt on a mitsubishi wd62528 62 inch tv?
Posted by maria c silva on
Robert Smith
    Champion:
  • 213 Answers
YES IT BY THE LAMP
Posted on Nov 25, 2013
2 Related Answers
yambo
Noe Z Bernabe
  • 230 Answers
SOURCE: Looking for a ballast part number and price Mitsubishi WD-C657
encompass.com or parstore.com is a good store parts.
Just provide model number tv.
Thank you
Posted on Aug 07, 2009
gopakumarg43
  • 76396 Answers
SOURCE: how can i get to the ballast board are fmt board on a mitsubishi wd62528 62 inch tv?
You're asking the way to access the ballast board, I assumes and posts this solution. You have to disassemble the set. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter" Disassembley procedure is given in detail with illustrations. I can't include all that illustrations and descriptions here by this window.
Posted on Apr 11, 2013
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
How can i get to the ballast board are fmt board on a mitsubishi wd62528 62 inch tv?
Apr 11, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
I have a mitsubishi wd-52631 and the red light is solid I just cleaned out the tv and got a new bulb but when I turn the tv on I get about 2 mins of picture and sound before it turns off. Does any one know...
It is possible either did not get all the dirty areas in front, and rear of set cleaned out or even that the ballast for the unit is this problem since it powers the lamp---lamp will come on and then turn off for a number of reasons.
The set does have a self diagnostic feature which usually is:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
May 02, 2012 | Mitsubishi WD-52631 52" Projection HDTV
I have a mitsubishi wd62725 green flashing led non stop replaced all the bad caps, 2 big and 4 smaller on power 4 1000u on fmt and 4 1000u on the dm board still getting the non stop led if i boot up with...
You can press the "DEVICE" and "MENU" keys on the front of the TV (not the remote) and the TV should flash an error code. Here is a chart.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
If the code is lets say 36 the LED will flash 3 times then pause then 6 flashes.
May 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I replace the lamp into my mitsubishi 61 inch tv lamp number 915P28010 however the lamp took to the tv. Now when I hit the power button the tv will not come on but u can hear the fans runnin. I had someone...
Question?
is your TV making any strange sounds like clicks or any thing else?
YES? ....making noises is the "Ballast"
http://www.discount-merchant.com/MITSUBISHI-38169103GR-Lamp-Ballast-Driver-p/1137373.htm
if you see half of your tv black or out of shape is the light engine!
http://www.discount-merchant.com/MITSUBISHI-RMD52-939P977A10-Light-Engine-p/1120406.htm
so i think it's going to be the ballast..
let me know i can help you more..
good luck!
Dec 31, 2009 | Televison & Video
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 62525 honeycomb pictues
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62526
Jan 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
