The machine works fine but the display screen just stopped showing colours. I can see the options but they are in black and white.
Saeco Philips coffee machine display screen doesn't light up?
I can still use it and I can barely see the options but display screen doesn't light up
I'm having it sent back for repairs, is there a quick fix for this issue so I do not have to send it back
I had the same issue. The red and yellow lights still worked but the green light did not. There are two screws on each side of the front panel. Once those are off you can pull the front panel off exposing the led screen and wiring. There are 3 small wires coming from the top of the screen that plug into a circuit board behind the screen. The green wire seemed to have a short because moving it around caused the green light to flicker back on. After repairing the wire's contract with the plug connector the green light works fine.
same here on two month old machine. Any solutions or chase down warranty service again? Thanks.
You need to order an LCD screen. Then open your machine and replace it is easy to do the part is $35
Like I said before under Soapywtr You need to order the LCD screen and replace it
