Question about T-Mobile Concord
My T-mobile Concord keeps shutting off when I try to factory reset it.
Okay so I have been trying to factory reset my T-mobile Concord phone and so I hold down the volume button and the power button but all that appears it a screen with a white box and an arrow coming out of the box pointing to a tiny android icon. I never get the triangle screen I get with my past Android phones. Then I hold down the menu button and I even tried pressing it repeatedly but nothing works. It just shuts off. And starts back up. I tried entering a google account but it isn't working either. Help?
AJ Yadav
    Master:
  • T-Mobile Master
  • 515 Answers
It will happen when you reset your factory reset
Posted on May 20, 2017
2 Related Answers
Anonymous
SOURCE: unlocked sidekick 3 won't get past "waiting for activation"
Press the top left button and "L" key at the same time to by-pass that screen and allow you to use the regular phone functions.
Posted on Feb 03, 2010
awaissabair
Big Boss
  • 580 Answers
SOURCE: side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Nov 02, 2012
How do i reset it
For sale? there should be an option for a factory reset in settings. Or are you trying to reboot the phone?
2helpful
My phone is locked because of too many wrong sim network pins
Hi Joe Ricker, Let's try to remove that lock, the only problem here is that you will loose all information and data that is stored in your phone. If that is OK with you, I'll try to explain how to factory reset.
Make sure that you have at least 50% of battery charge. With the phone on, take the battery out and place it back. press the volume down and power key at the same time until you see an android icon with an exclamation mark, while doing this step you will see the original android logo, it's not that one. The one I'm explaining here comes after the original android logo.
Once you see the android with the exclamation mark, let go of the buttons. To activate the recovery tap the home key, now scroll down to wipe data/ factory to highlight it, now tap the menu to select, scroll down to yes and tap the menu.
Repeat the same step for wipe cache.
Back at the main recovery page, scroll up to reboot, tap the menu and you should have a brand new factory reset ZTE 768 with no pattern or lock.
I can't receive or make phone calls but can receive texts
Here is one thing to try;
1. With the phone ON, open the case and remove the battery.
2. Press the power button and hold for 15 seconds. Release.
3. Return the battery into the phone, put the cover on and turn on the phone.
4. See if the phone will make a call.
Second Thing to try. You NEED an SD memory card installed for this to work!:
1. GO to the Play store and install Super Backup.
2. Open the app and back up ALL contacts, SMS (text) messages, Apps, and call logs (if needed) Calendars and Bookmarks. If you don't use all of these, then ignore them.
3. Do a FACTORY RESET on the phone. This will return it to the 'good as new' condition it was in when you got it. HERE is the link -----> Reset Mobile Concord
SKIP #7, OR YOU WILL LOSE ALL OF YOUR BACKUPS.
5. Now try to make a phone call and see if it works correctly.
6. When you are finished, return to the Play Store and install Super Backup. Then you can tap the buttons and check all the boxes of whatever you wish to restore.
If this does not help and your phone is under warranty, return it to T-Mobile for help. They may have other tricks to perfrom that could help.
My Concord reboots at random times and once its rebooted it says No SIM card. So I have to turn my phone off and back on again. HELP!
i pretty sure it is software issue. my samsung S3 did the same thing. to get it to stop i updated the software (operating system). but before that i uninstalled operating system and went back to old operating system
HOW DO I RESET MY T MOBILE PHONE
Hi whether you want to reset your phone which is locked with t-mobile network ...Then first try default code like 0000 or 1234 to reset your phone ..If this code didn't help to reset your phone then have a look at sites like Unlock-Free.com here they generate master reset code for some nokia and alcatel mobile models at free of cost ..You can make use of this code and reset your phone ....
2helpful
My t- moblie concord phone keeps restarting itself
I just solved this problem on my son's phone. I removed the sim card and sd memory card. Then I had to do a factory reset. Press and hold the volume down and the power button until the picture of the android shows up. Then the menu button. This will open the recovery screen. Use the volume control to move up and down the screen and select the restore by pressing the home key. After I made sure it would turn on and stay on, I replaced sim and sd card.
My Concord shuts down multiple times a day
May have a low memory issue going on.. Turn off any unnecessary features, and try pulling the battery out and putting it back in.. If that doesn't help, you my have to do a hard reset and restore it back to its factory condition... Here are the instructions to reset your phone: To perform a hard reset using hardware keys, follow these steps: Power off the device. Press and hold Volume Down key. Press and hold Power key until the Android and Triangle logo appears on screen. Let go of buttons once the logo appears. Press the device Home key. When the Factory Data Reset option appears, use the Volume keys to scroll to and select it with the Menu key. When Wipe data? appears, use the Volume keys to highlight Yes, and select it with the Menu key. Once Data Wipe Complete appears, use the Volume keys to highlight Reboot System Now and select it with the Menu key. Hope this helps...
4answers
How do i factory reset my T-Mobile Concord?
Hello Dear:
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
I want to factory reset my t mobile concord
Hello:
Default 4 Digit user code: 1234,1122 or 0000
My tmobile concord wont reboot
Try taking the battery out for five minutes.
T-Mobile Concord Logo
Top T-Mobile Cell Phones Experts
Ekse
Muzahura Frank
Oloyede Monsuru
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
