This is for different year and model, but take a look
SOURCE: 1984 Mercedes-Benz 500 SEL
In the driver's side trunk along the wheel well and behind the wheel well cover you will find the sunroof motor. There is a plastic knob that can be turned to close/open the roof manually. The socket tool is part of the original toolkit that came with the car, but otherwise, you can locate one that will fit. Don't use pliers as the plastic easily breaks. Meanwhile, have you looked at the fuse or toggled the switch hard to work? If the motor works, but doesn't move there is an adjustment on the motor's clutch that can be tightened. Hope this helps.
Videos that might help
https://www.google.com/search?q=2008+mercedes+c300+sunroof+won%27t+close
My last pay test was $9500 operating 12 hours per week on line. my sisters buddy has been averaging 15k for months now and she works approximately 20 hours every week. i can not accept as true with how easy it become as soon as i tried it out.
This is what do,................................... http://Www.Self25.com
In the driver's side trunk along the wheel well and behind the wheel well cover you will find the sunroof motor. There is a plastic knob that can be turned to close/open the roof manually. The socket tool is part of the original toolkit that came with the car, but otherwise, you can locate one that will fit. Don't use pliers as the plastic easily breaks. Meanwhile, have you looked at the fuse or toggled the switch hard to work? If the motor works, but doesn't move there is an adjutment on the motor's clutch that can be tightened. Hope this helps.
SOURCE: 1997 e class mercedes sunroof problem
hello,try to clean the rail,if not corrected,your sunroof motor need to check or replaces if necessary,ty
SOURCE: How do I manually closed the sunroof that is stuck
in the trunk on the drivers side there is a plastic bolt to turn, in your tool kit should be a socket thing that should fit it to turn it.
Testimonial: "Thanks. I see it. It has a hex head but not a very high profile. Do you turn it clockwise or counterclockwise to close it? Thanks a lot!"
SOURCE: I have mercedes benz c300
have emergency pads in rear checked,some cars have seperate pads for emergency.possibly bad sensor or caliper.hope this helps,see if local advance or auto zone can scan for free,or help further.
Help!!
Help!!
