Cameras Logo
A
Anonymous Posted on Apr 10, 2013
Cannon sx160 is, says ISO start tracking AF, what does this mean?
ISO start tracking AF, appears as soon as I turn my camera on and it won't let me take pictures.
Thandiwe
Level 2:
Habit-Forming:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 65 Answers
  • Posted on Jul 24, 2022
Thandiwe
Expert
Level 2:
Habit-Forming:
Greenhorn:
Answers
65
Questions
0
Helped
15875
Points
113
AF, in this context, refers to autofocus. Using the autofocus function of a camera, you're allowing the focus motor to adjust to change focus instead of manually moving it yourself. When working in the autofocus setting, you can also often select the focusing mode as well.
5 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Aug 30, 2009
SOURCE: I turn on my Nikon CoolPix it starts to turn on & off by itself?
You can change the ISO in the setup menu...I suggest auto ISO. You can also go to "reset" in the setup menu to try to get back to factory default settings.
Nathan Reimche-Vu
  • 80 Answers
  • Posted on Apr 06, 2010
SOURCE: Error code 99. Please tellme what this means.
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Anonymous
  • 14 Answers
  • Posted on Mar 01, 2011
SOURCE: I'm not getting crisp, in-focus
You can try a few things to see if they help
  • First is to power off the camera and detach and reattach the lens just to make sure you are getting a good connection for the auto-focus
  • The second thing you want to do is shoot in RAW format to be sure you are able to retain the most information in the image.
  • Make sure the noise reduction is turned off in the camera menu
  • If you aren't using a cable shutter release you can opt to have the shutter delay after pressing the button. This will allow the camera to stop shaking from you pressing the button before it releases the shutter. You can find this option in the menu. Camera 2 > Anti-Shock > 3 sec.
  • Another consideration is the quality of the lens you are using. The G10 has great glass while a kit lens from Olympus may not give the fidelity throughout like the G10 does. You can try another lens if you have one available to see if this is the case. The G10 is a single purpose camera that has a great lens on it. The E-500 may need a better quality lens on it in order to achieve the sharpness you desire. Olympus makes a great 50mm macro that has an f2.0 brightness.
  • You can also set the camera to manual focus and then choose to do focus bracketing. This is a little more involved and you can find out how to do so in the manual for the camera.
Advanced Camera Manual for E-500
Anonymous
  • 6771 Answers
  • Posted on Mar 22, 2011
SOURCE: When I turn on the
The problem is in the systems control board, "controls vital areas of the camera" from your description the operation is intermittent when switching from manual to auto, it indicates an hairline crack in the systems board, a tough problem to nail down. The only option is to send it to Sony for assessment before actual repairs are implemented.
Joseph Hoffmann
  • 1756 Answers
  • Posted on Aug 04, 2011
SOURCE: camera when turned on zooms
Hi, Check and/or replace batteries. If lens is stuck slowly and carefully force it back in. Good luck.
  • turn off your camera
  • set the knob to manual mode see if this works
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
My N55 won't let me depress the shutter (to take the shot) when it's on automatic setting. I depress once (half-way) for autofocusing--which seems to work fine. No error message. But then, the N55...
Could be your lens is not communication with the body. If the lens is not telling the camera that the AF has locked on an object then it won't allow the camera to fire. Make sure that the camera is indeed locking the AF on the object. If there isn't enough contrast (for example a plain wall) then it wont be able to lock onto it. This would usually explain why it works on manual but not on auto (I assume you mean the focus setting and not the camera's modes). If you're still having issues I recommend you contact a nearby Nikon authorized service center for assistance and possible repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
How to get several focus points in a d7000 viewfinder?
Hi, On the D7000 you need to press the button on the side of the camera that's in the middle of the AF/M switch and then you use to switch to decide whether it's in 1 point autofocus (hence forth called AF), 9 point dynamic area AF, 21 point dynamic area AF, 39 point dynamic area AF, 3D tracking AF or auto area AF. If you need more help with switching AF modes let me know and I can help you out =)
2helpful
I don't understand the numbers of the drive ISO ?
You can get a manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=12929
AF allows you to select between the various autofocus modes. WB allows you to set the white balance, to compensate for the color of the light. Drive allows you to select the drive mode, from single to continuous to remote. ISO allows you to set the sensor sensitivity, similar to choosing film speed for analog cameras.
Iso to auto
On the back of the camera to the Right of the LCD there is a up-down-left-right-center switch. push the up one. (Labeled ISO) then use the same selector switch to select the ISO you want and then press the shutter half way down. If you are shooting in a low light situation, the auto focus sometimes will not work. Change the switch on the lens from AF to MF and focus manually.
Turning af beam off
The same lamp used for AF is also used as a preflash for redeye reduction. Turn off redeye reduction as well as AF assist.
Top Cannon Cameras Experts
ZJ Limited
ZJ Limited
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Cannon Camera Expert? Answer questions, earn points and help others
