Explanation of lights
When the appliance is turned on Flashing lights: the appliance is heating up to make coffee Lights on steadily: the appliance is ready to make coffee The lights flash rapidly: the tank is empty or the appliance will not make coffee. See the section "2. Filling the water tank" 3. https://www.delonghi.com/Global/countries/se/Manualer/0132106141.pdf
E3 indicates that the air in take filter is clogged and needs to be removed and cleaned. Be sure to turn the unit OFF and unplug it, before removing the filter.
poke something up the outlet hole .....pin or something .. or if this dont work u need service and replacement parts .. bsc appliance 07779933829 we carry out repair service via post anywere.
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
We had the same problem. The on/off switch is likely to be broken inside. We tried to fix it but its likely the pcb is damaged. If you contact Delonghi direct they will help resolve. They sent us a new heater (10yr guarantee)!
