My gateway GT5654 desktop PC.makes a beeping sound when i turn it on.how do i fix it?
Perhaps this will help: http://www.computerhope.com/beep.htm
SOURCE: had a power surge... a
You can get a powr supply for this, but if the surge went passed that and smoked the motherboard then your going to need to replace that as well but a new poer supply should shore this up and you can get them from frys.com,tigerdirect.com you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: my Gateway GT5654 desktop just quit in the middle
Based on my experience, the most probable cause of your problem is the RAM. Try Cleaning the RAM first by removing it from the slot, and rub the pins with a pencil eraser. As shown on the image below:
Then re-install it to the motherboard. If problem persist, you may need to replace your RAM.
Note: If you have two RAMs on your pc, might as well clean them both, and then test each RAM to find out if either one of them or both are busted.
SOURCE: I don't know how to turn on wireless radio adapter
It should either be in the settings for the card, (software) the control panel around network connections or the card on device manager.
SOURCE: does the Gateway GT5654 Desktop PC have an audio
yes, on the back of the computer usually a light blue input port. the are labeled with an icon with the arrow pointing inward on the icon.
