Question about IBM ThinkPad Computers & Internet
When i click on a picture the screen is black
Posted by gloria grant on
Priyanshu
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 41 Answers
There may be problem with your image viewer. try to reset all settings of image viewer to default or try to install any other third party image viewer(image viewing software).
Posted on Apr 11, 2013
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
Camera screen is black no image appears to view to take a picture??
Time for a new camera perhaps ? Sreen is faulty, most likely and fixing may be too expensive.
Sep 11, 2014 | Kodak EasyShare MD853 Digital Camera
Nikon coolpix s600 black screen or lines after taking a picture
Black screen after clicking a picture means aperture motor not working or lens flexible circuit damaged, it has to be checked by expert technician & is replaceable part.
Sep 30, 2017 | Nikon Coolpix S600 Digital Camera
Sony DSC-T1 screen is black. Does not recognize
There may be the issue with the CCD (Image Sensor Device) of the Camera. This is a known issue with this Camera.
Refer this article to confirm this:
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Check whether the LCD screen of the Camera looks similar as given on the page.
If yes, click on the "Yes" button at the end of the page to create an online Repair Request for sending the Camera to the Sony Factory Service Center.
Sep 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Canon PowerShot A60~~~Viewing screen black/fuzzy won't take pict.
Its known problem of ccd imager in Canon A60 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jul 24, 2009 | Canon PowerShot A60 Digital Camera
Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Mar 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Dark burn in? at top and bottom of screen. TV is only 16m old.
PixelProtector is a tool for fixing stuck pixels, removing screen burn, correctly calibrating screens for optimal performance and gaining the best possible picture. Any large screen television is an investment. Poor set-up and calibration can degrade the quality of a television's image and severely threaten the life of the screen.
If you own a large plasma or LCD television with a DVD player and want to achieve optimum performance, PixelProtector is highly recommended.
3 ways to remove burn-in
1. PixelProtector for Removing Screen Burn.
2. downloading a free program called JScreenFix
3.
Screen Burn Removal Using Your PC.
If you can hook your PC up to your screen burnt TV try this. Create a folder in 'My Documents' called 'Screen Burn'. I'm not joking keep reading. Now open up a picture editor like 'paint' available on all Windows PC's. When you run 'Paint' a blank white document is what you should have in front of you. That is exactly what you need. Select File – Save as and name your picture 'white'. Be sure to save it in the folder you just created.
Next you need to click on the 'black' section of the colour pallet at the bottom of the 'Paint' window. After you have selected black click on the 'Fill' icon (a tipped paint pot) on the left. Now simply click in the middle of your white picture and it should become totally black. Select File – Save as and name you picture 'black'. Again be sure to save it in the folder called 'Screen Burn'. You don't need paint any more so you can shut it down.
Now right click on the Windows desktop an select Properties – Screen Saver and using the drop down list select 'My Pictures Slide Show'. Now to configure the slide show. Click Settings and configure as follows. Slide the bar to 'More' so that pictures change frequently. Slide the next bar to 'Larger' so pictures fill the whole screen. Now click the 'browse' button and find the folder you made called 'Screen Burn'. In the next set of options:- Check 'Stretch Small Pictures', Un-check 'Show File Names', Check 'Use Screen Transitions' and finally un-check 'Allow Scrolling Through Pictures With The Keyboard'. Save the options.
Different versions of Windows might have slightly different configuration options but as long as the result is a completely filled (no borders), alternating white and black screen with no writing then it will probably help.
Now set your screen saver to 1 minute and leave the keyboard and mouse well alone.
As with the 'snow' and 'signal pattern' leave this for a while to see some results. If you use your TV for the PC then it might be a good idea to use this as your regular screen saver and run it frequently.
The only snag is the headache of connecting the PC up and the fact that removal technique will not be running at your screens native resolution.
Here are some more resources:- PixelProtector Screen Burn Removal and our old screen burn home page
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
When taking a picture, camera screen is black
It is problem of bad CCD imager IC and this part needs to be replaced.
Sony will repair it free of cost as per announced scheme for this problem in DSC-T1 Camera.
Please click on Sony CCD Support for details. If you are in other country, let me know to guide you more.
Thank you.
Dec 09, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Screen is Black, light I'm in a dark black room black
Same problem as you described. I haven't figured it out yet.
Jul 20, 2008 | Samsung L700 Digital Camera
Black Screen When Open, but the Picture quality is fine
in the lower right hand corner there is a button that has disp. on it just click that during picture taking mode and it will return to normal
Dec 25, 2006 | Canon PowerShot SD600 Digital Camera
Computers & Internet Logo
Top IBM Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
