SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
SOURCE: my sony mdr-7506 headphones stopped working,
As long as there is no inbuilt amp or something special to this make, then the problem will be most likely the cable or the Jack plug at the end. There will have a clean break (internal) cutting off all sound. If you are good with a soldering iron then you should be able to get a new cable with plug, or you can try cutting the old jack and fitting a new plug. If you need to go inside to fit the cable then the access screws will be under the foam and ear pads.
SOURCE: The jack on my Sony MDR-NC6 has broken off. Can I
See my tip on dodgy cable/jack on headphones. If the jack is different to the one shown, you should be able to get it from Maplin (UK user) or Radio Shack (USA).
