SOURCE: Kenmore upright freezer alarm sounds constantly
replace the battery in the grill or the hi-voltage control under the unit in the back
SOURCE: kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
SOURCE: freeezer with no compressor activity
Make sure the wires leading to the compressor are working. If not, the compressor might have given up the ghost.
SOURCE: Freezer quit (Kenmore Upright)
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
Hello richardso903 - Once again try resetting the freezer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. Set the unit to ON, by pressing and holding the Power button for approximately ten seconds. If issue persists and freezer does not turn on, then the unit may be experiencing a wiring failure, faulty plug or control board. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
