Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
